Combobox for API 3.1??
1342
11-18-2012 07:18 PM
SunilPalkar
Dear All,
Can Combo-box  supported for version 3.1 ( ArcGIS Java Script API) ??
I am looking similar example here  ??
Any help will be great..
Thanks in advance : )
derekswingley1
Yes, it still works. One of the Dojo changes that happened (I don't recall exactly when it happened) is that you set the store for a dijit using .set("store", store) instead of .store = store.
Here's a version of the page from the blog post that uses 3.2:  http://jsfiddle.net/4yghv/
The key line of code is:
dijit.byId("mySelect").set("store", store);
I also modified the code to use OBJECTID as the store's identiifer. This causes lots of duplicates to be displayed in the ComboBox and that's not a good idea for an actual app, but the link above shows that you can still use a ComboBox with current versions of the JS API.
derekswingley1
SunilPalkar
Thanks a lot for your information...you are hero !!! 🙂
thanks..
