Combine two Examples with Buttons to activate code
10791
39
04-01-2014 08:18 AM
jaykapalczynski
Honored Contributor
I am combining a few examples from the JS API. I am trying to make them only active when a button is clicked.
On Load neither are active. I click my identify button and it identifies. I then click my Buffer Button and it runs the buffer code, buffers and returns results to a grid.
It does not appear that the identify is working after the Buffer button is clicked (perfect)
But after I run the Buffer Tool and click back to the identify it still runs the Buffer Code....
I am looking for a way to "turn it off" the buffer code when I click the Identify button. (for a lack of better words)
I am not sure where I can:
1. Turn off the Buffer Tool - I tough of putting some sort of code in the IDENTIFY BUTTON code to disable it?
2. Remove the graphics from the feature layer that were created when the selection occurs from the buffer
 on(dom.byId("IDENTIFY"), "click", function () {
        initializeSidebar(app.map);
 //Clear Graphic Circle from BufferTool
 app.map.graphics.clear();
 clearContent();
 // CLOSE THE PANE WHEN SELECTED
 dijit.byId("Tools").set('open',false); //Close
  on(dom.byId("BUFFER"), "click", function () {
 dom.byId("featureCount").innerHTML = "Click Identify Tool to select feature(s)";
        featureLayer0.setInfoTemplate(null);
        featureLayer1.setInfoTemplate(null);
        app.map.infoWindow.hide();
        clearContent();
 BufferTool(app.map);
Function BufferTool
    function BufferTool(map){
        dialog = new TooltipDialog({
          style: "position: absolute; width: 100px; font: normal normal normal 10pt Helvetica;z-index:100"
        dialog.startup();
       // selection symbol used to draw the selected census block points within the buffer polygon
        var point = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          25,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_NULL,
            new Color([137, 214, 171, 0.9]),
          new Color([137, 214, 171, 0.5])
        app.map.on("load", function(){
          app.map.graphics.enableMouseEvents();
          app.map.graphics.on("mouse-out", closeDialog);
        //listen for when the onMouseOver event fires on the countiesGraphicsLayer
        //when fired, create a new graphic with the geometry from the event.graphic and add it to the maps graphics layer
        featureLayer.on("mouse-over", function(evt){
         var t = "<b>${SITENAME}</b><hr><b>Region: </b>${REGION}<br>";
          var content = esriLang.substitute(evt.graphic.attributes,t);
          var highlightGraphic = new Graphic(evt.graphic.geometry,point);
          app.map.graphics.add(highlightGraphic);
          dialog.setContent(content);
          domStyle.set(dialog.domNode, "opacity", 0.85);
          dijitPopup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY
        var symbol2 = new SimpleMarkerSymbol(
          12,
            new Color([247, 34, 101, 0.9]),
          new Color([207, 34, 171, 0.5])
        featureLayer.setSelectionSymbol(symbol2);
        // change cursor to indicate features are click-able
        featureLayer.on("mouse-over", function () {
            app.map.setMapCursor("pointer");
        featureLayer.on("mouse-out", function () {
            app.map.setMapCursor("default");
        // Add the Feature Layer To Map
        app.map.addLayer(featureLayer);
        // geometry service that will be used to perform the buffer
        var geometryService = new GeometryService("https://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        //when the map is clicked create a buffer around the click point of the specified distance.
        app.map.on("click", function(evt){
          //define input buffer parameters
          var params = new BufferParameters();
          params.geometries  = [ evt.mapPoint ];
          params.distances = [ 50 ];
          params.unit = GeometryService.UNIT_STATUTE_MILE;
          geometryService.buffer(params);
        geometryService.on("buffer-complete", function(result){
          // draw the buffer geometry on the map as a map graphic
          var symbol2 = new SimpleFillSymbol(
            SimpleFillSymbol.STYLE_NULL,
              SimpleLineSymbol.STYLE_SOLID,
              new Color([105,105,105]),
            ),new Color([255,255,0,0.25])
          var bufferGeometry = result.geometries[0]
          var graphic = new Graphic(bufferGeometry, symbol2);
          app.map.graphics.add(graphic);
 //Select features within the buffered polygon. To do so we'll create a query to use the buffer graphic
          //as the selection geometry.
          var query = new Query();
          query.geometry = bufferGeometry;
   // Select the Points within the Buffer and show them
          featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){
          // Query for the records with the given object IDs and populate the grid
          featureLayer.queryFeatures(query, function (featureSet) {
            updateGrid(featureSet);
   } // End Function BufferTool
      function closeDialog() {
          dijitPopup.close(dialog);
      function updateGrid(featureSet) {
        var data = arrayUtils.map(featureSet.features, function (entry, i) {
          return {
            REGION: entry.attributes.REGION,
            WATERBODY: entry.attributes.WATERBODY,
            TYPE: entry.attributes.TYPE,
            ACCESSAREA: entry.attributes.ACCESSAREA,
        grid.store.setData(data);
        grid.refresh();
    // markerSymbol is used for point and multipoint, see http://raphaeljs.com/icons/#talkq for more examples
        var markerSymbol = new SimpleMarkerSymbol();
        markerSymbol.setPath("M16,4.938c-7.732,0-14,4.701-14,10.5c0,1.981,0.741,3.833,2.016,5.414L2,25.272l5.613-1.44c2.339,1.316,5.237,2.106,8.387,2.106c7.732,0,14-4.701,14-10.5S23.732,4.938,16,4.938zM16.868,21.375h-1.969v-1.889h1.969V21.375zM16.772,18.094h-1.777l-0.176-8.083h2.113L16.772,18.094z");
        markerSymbol.setColor(new Color("#00FFFF"));
    // lineSymbol used for freehand polyline, polyline and line.
        var lineSymbol = new CartographicLineSymbol(
          CartographicLineSymbol.STYLE_SOLID,
          new Color([55,77,173,.75]), 1.5,
          CartographicLineSymbol.CAP_ROUND,
          CartographicLineSymbol.JOIN_MITER, 5
    // fill symbol used for extent, polygon and freehand polygon, use a picture fill symbol
    // the images folder contains additional fill images, other options: sand.png, swamp.png or stiple.png
 var fillSymbol = new SimpleFillSymbol(
          SimpleFillSymbol.STYLE_SOLID,
            new Color([55,77,173,0.35]),
          new Color([125,125,125,0.35])
    // function toolbar
        function initToolbar() {
   alert("In initToolbar");
          tb = new Draw(map);
          tb.on("draw-end", addGraphic);
     // event delegation so a click handler is not
     // needed for each individual button
          on(dom.byId("info"), "click", function(evt) {
            if ( evt.target.id === "info" ) {
              return;
            var tool = evt.target.id.toLowerCase();
            map.disableMapNavigation();
            tb.activate(tool);
    // add graphic
        function addGraphic(evt) {
          //deactivate the toolbar and clear existing graphics
          tb.deactivate();
          app.map.enableMapNavigation();
          // figure out which symbol to use
          var symbol;
          if ( evt.geometry.type === "point" || evt.geometry.type === "multipoint") {
            symbol = markerSymbol;
          } else if ( evt.geometry.type === "line" || evt.geometry.type === "polyline") {
            symbol = lineSymbol;
          else {
            symbol = fillSymbol;
          app.map.graphics.add(new Graphic(evt.geometry, symbol));
KenBuja
MVP Esteemed Contributor
Since you still connecting the click event in that function, you'll have to disconnect it.
jaykapalczynski
Honored Contributor
are you referring to this
Not sure how to disconnect it with it in the Buffer Function from a button click
          params.distances = [ 10 ];
jaykapalczynski
Honored Contributor
Should I add something like this??? I havent defined it so I am unsure what to disconnect in the button click
var BufferClick = connect.connect(map, "click", function(evt)){
and then disconnect from the button click?
connect.disconnect(BufferClick );
jaykapalczynski
Honored Contributor
I am using the Map.On from the Buffer Button
var BufferClick = app.map.on("click", BufferTool(app.map));
which calls the Buffer Code, which in turn I am creating another Click event to define the Buffer Params
I have not defined the click event with a variable in the Buffer Code so I am unsure how to do this and then disconnect.
Back in the Identify button I need to disconnect this Click event that sets the Buffer Parameters.
Stuck here.
Could or should I do this?  And then attempt to disconnect the BufferClick in the Identify button click?
var BufferClick = app.map.on("click", function(evt){
Then disconnect in the Identify button?
BufferClick.Remove();
so confused here
KenBuja
You'll have to declare the variable BufferClick outside the BufferTool function so that it can be referred in other functions (read up on variable scope). Something like
var map;
var BufferClick;
require(["esri/map", etc
    function BufferTool(map) { //although if you declared map outside the require, you don't need to pass it like this
         // code for function
        // rest of code in function
jaykapalczynski
Honored Contributor
This is all my code OUTSIDE the Buffer Function....Still dont know where I should be disconnecting from the BufferClick in the Buffer Code....
I had that code that you showed in your example....but dont know what to write in regards to the IDENTIFY Button to disconnect the BufferClick
    var tb;
    var app = {};
    var BufferClick;
    require([
        "dojo/ready",
        "dojo/on",
        "dojo/_base/connect",
        "dojo/dom",
        "dojo/dom-construct",
        "dojo/parser",
        "dijit/registry",
        "esri/layers/FeatureLayer",
     "esri/layers/ArcGISDynamicMapServiceLayer",
     "esri/InfoTemplate",
        "esri/renderers/UniqueValueRenderer",
        "esri/renderers/SimpleRenderer",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
  "dijit/layout/BorderContainer",
  "dijit/layout/ContentPane",
  "esri/map",
  "esri/toolbars/draw",
        "esri/symbols/SimpleFillSymbol",
        "esri/tasks/query", "esri/tasks/QueryTask",
        "esri/tasks/GeometryService", "esri/tasks/BufferParameters",
        "esri/TimeExtent", "dojo/number", "dojo/date/locale",
        "dojo/store/Memory", "dgrid/OnDemandGrid",
        "esri/lang", "dojo/dom-style", "dijit/TooltipDialog", "dijit/popup",
        "dojo/_base/Color", "esri/graphic",
        "esri/symbols/PictureFillSymbol", "esri/symbols/CartographicLineSymbol",
  "esri/dijit/BasemapGallery",
  "esri/dijit/BasemapToggle",
  "esri/request",
  "esri/config",
        "dojo/_base/array",
  "esri/dijit/Print",
  "esri/tasks/PrintTemplate",
  "esri/arcgis/utils",
  "esri/domUtils",
  "esri/dijit/Popup",
  "dojo/domReady!"
    ], function(
        ready,
        on,
        connect,
        dom,
        domConstruct,
        parser,
        registry,
        FeatureLayer,
    ArcGISDynamicMapServiceLayer,
    InfoTemplate,
  UniqueValueRenderer,
     SimpleRenderer,
     SimpleMarkerSymbol,
     SimpleLineSymbol,
        BorderContainer,
        ContentPane,
        Map,
 Draw,
        SimpleFillSymbol,
        Query, QueryTask,
        GeometryService, BufferParameters,
        TimeExtent, number, locale,
        Memory, OnDemandGrid,
        esriLang, domStyle, TooltipDialog, dijitPopup,
        Color, Graphic,
        PictureFillSymbol, CartographicLineSymbol,
        BasemapGallery,
        BasemapToggle,
        esriRequest,
        esriConfig,
        arrayUtils,
        Print,
        PrintTemplate,
        arcgisUtils,
        domUtils,
        Popup
    parser.parse();
    //setup event handlers for the next/previous buttons
    on(dom.byId("previous"), "click", selectPrevious);
    on(dom.byId("next"), "click", selectNext);
    esri.config.defaults.io.proxyUrl = "https://fwis.gov/proxypage_net/proxy.ashx";
    app.map = new esri.Map("map", {
       basemap: "topo",
       center: [-77.4329, 37.5410],
       zoom: 7,
       slider: false,
       showAttribution:false,
       logo: false
    app.map.infoWindow.set("popupWindow", false);
            app.map.on("click", function () {
                clearContent();
            app.map.infoWindow.on("hide", clearContent);
  clearContent();
                clearContent();
jaykapalczynski
Honored Contributor
HERE Is all the Buffer Code...REST OF CODE in previous post
        dialog.startup();
          25,
          dijitPopup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY
          12,
          return {
        grid.refresh();
    // function toolbar
          tb = new Draw(map);
              return;
            tb.activate(tool);
    // add graphic
          tb.deactivate();
          var symbol;
          else {
jaykapalczynski
Honored Contributor
I know I am skating all around the solution but just cant seem to figure it out...all your help is appreciated.
Just trying to disconnect from the "BufferClick" when I click the IDENTIFY button....it keeps running the buffer code ....
****If I use the Buffer Tool via the Buffer Button the code runs...If I go back and click the IDENTIFY button it does not run the Buffer Code but the Identify is no longer working?
PLEASE refer to the last two posts above....
KenBuja
Could you put together a Fiddle that's a simplified version of this that replicates the problem?
jaykapalczynski
Honored Contributor
Here is a JSFiddle.....I tried to make as simple as possible....
1.  When you open it you can click to "Tools" this will drop the pane down and expose the IDENTIFY and BUFFER buttons
2. Click the IDENTIFY tool and you should be able to click the Green Graphics and display data in the left pane
3. Now click on the BUFFER tool....and try and click near one of the Green graphics again....it should run the Buffer Code but does not....you need to refresh the page...
4. after refreshing the page go into the BUFFER button and then click near a green graphic...the code will run....
5. then go back and click the IDENTIFY button....nothing happens.
http://jsfiddle.net/Jaykapalczynski/n7yux/20/
Hope you can help out...I really appreciate your help here....
