Combine two Examples with Buttons to activate code
10738
39
04-01-2014 08:18 AM
jaykapalczynski
Honored Contributor
I am combining a few examples from the JS API. I am trying to make them only active when a button is clicked.
On Load neither are active. I click my identify button and it identifies. I then click my Buffer Button and it runs the buffer code, buffers and returns results to a grid.
It does not appear that the identify is working after the Buffer button is clicked (perfect)
But after I run the Buffer Tool and click back to the identify it still runs the Buffer Code....
I am looking for a way to "turn it off" the buffer code when I click the Identify button. (for a lack of better words)
I am not sure where I can:
1. Turn off the Buffer Tool - I tough of putting some sort of code in the IDENTIFY BUTTON code to disable it?
2. Remove the graphics from the feature layer that were created when the selection occurs from the buffer
 on(dom.byId("IDENTIFY"), "click", function () {
        initializeSidebar(app.map);
 //Clear Graphic Circle from BufferTool
 app.map.graphics.clear();
 clearContent();
 // CLOSE THE PANE WHEN SELECTED
 dijit.byId("Tools").set('open',false); //Close
  on(dom.byId("BUFFER"), "click", function () {
 dom.byId("featureCount").innerHTML = "Click Identify Tool to select feature(s)";
        featureLayer0.setInfoTemplate(null);
        featureLayer1.setInfoTemplate(null);
        app.map.infoWindow.hide();
        clearContent();
 BufferTool(app.map);
Function BufferTool
    function BufferTool(map){
        dialog = new TooltipDialog({
          style: "position: absolute; width: 100px; font: normal normal normal 10pt Helvetica;z-index:100"
        dialog.startup();
       // selection symbol used to draw the selected census block points within the buffer polygon
        var point = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          25,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_NULL,
            new Color([137, 214, 171, 0.9]),
          new Color([137, 214, 171, 0.5])
        app.map.on("load", function(){
          app.map.graphics.enableMouseEvents();
          app.map.graphics.on("mouse-out", closeDialog);
        //listen for when the onMouseOver event fires on the countiesGraphicsLayer
        //when fired, create a new graphic with the geometry from the event.graphic and add it to the maps graphics layer
        featureLayer.on("mouse-over", function(evt){
         var t = "<b>${SITENAME}</b><hr><b>Region: </b>${REGION}<br>";
          var content = esriLang.substitute(evt.graphic.attributes,t);
          var highlightGraphic = new Graphic(evt.graphic.geometry,point);
          app.map.graphics.add(highlightGraphic);
          dialog.setContent(content);
          domStyle.set(dialog.domNode, "opacity", 0.85);
          dijitPopup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY
        var symbol2 = new SimpleMarkerSymbol(
          12,
            new Color([247, 34, 101, 0.9]),
          new Color([207, 34, 171, 0.5])
        featureLayer.setSelectionSymbol(symbol2);
        // change cursor to indicate features are click-able
        featureLayer.on("mouse-over", function () {
            app.map.setMapCursor("pointer");
        featureLayer.on("mouse-out", function () {
            app.map.setMapCursor("default");
        // Add the Feature Layer To Map
        app.map.addLayer(featureLayer);
        // geometry service that will be used to perform the buffer
        var geometryService = new GeometryService("https://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        //when the map is clicked create a buffer around the click point of the specified distance.
        app.map.on("click", function(evt){
          //define input buffer parameters
          var params = new BufferParameters();
          params.geometries  = [ evt.mapPoint ];
          params.distances = [ 50 ];
          params.unit = GeometryService.UNIT_STATUTE_MILE;
          geometryService.buffer(params);
        geometryService.on("buffer-complete", function(result){
          // draw the buffer geometry on the map as a map graphic
          var symbol2 = new SimpleFillSymbol(
            SimpleFillSymbol.STYLE_NULL,
              SimpleLineSymbol.STYLE_SOLID,
              new Color([105,105,105]),
            ),new Color([255,255,0,0.25])
          var bufferGeometry = result.geometries[0]
          var graphic = new Graphic(bufferGeometry, symbol2);
          app.map.graphics.add(graphic);
 //Select features within the buffered polygon. To do so we'll create a query to use the buffer graphic
          //as the selection geometry.
          var query = new Query();
          query.geometry = bufferGeometry;
   // Select the Points within the Buffer and show them
          featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){
          // Query for the records with the given object IDs and populate the grid
          featureLayer.queryFeatures(query, function (featureSet) {
            updateGrid(featureSet);
   } // End Function BufferTool
      function closeDialog() {
          dijitPopup.close(dialog);
      function updateGrid(featureSet) {
        var data = arrayUtils.map(featureSet.features, function (entry, i) {
          return {
            REGION: entry.attributes.REGION,
            WATERBODY: entry.attributes.WATERBODY,
            TYPE: entry.attributes.TYPE,
            ACCESSAREA: entry.attributes.ACCESSAREA,
        grid.store.setData(data);
        grid.refresh();
    // markerSymbol is used for point and multipoint, see http://raphaeljs.com/icons/#talkq for more examples
        var markerSymbol = new SimpleMarkerSymbol();
        markerSymbol.setPath("M16,4.938c-7.732,0-14,4.701-14,10.5c0,1.981,0.741,3.833,2.016,5.414L2,25.272l5.613-1.44c2.339,1.316,5.237,2.106,8.387,2.106c7.732,0,14-4.701,14-10.5S23.732,4.938,16,4.938zM16.868,21.375h-1.969v-1.889h1.969V21.375zM16.772,18.094h-1.777l-0.176-8.083h2.113L16.772,18.094z");
        markerSymbol.setColor(new Color("#00FFFF"));
    // lineSymbol used for freehand polyline, polyline and line.
        var lineSymbol = new CartographicLineSymbol(
          CartographicLineSymbol.STYLE_SOLID,
          new Color([55,77,173,.75]), 1.5,
          CartographicLineSymbol.CAP_ROUND,
          CartographicLineSymbol.JOIN_MITER, 5
    // fill symbol used for extent, polygon and freehand polygon, use a picture fill symbol
    // the images folder contains additional fill images, other options: sand.png, swamp.png or stiple.png
 var fillSymbol = new SimpleFillSymbol(
          SimpleFillSymbol.STYLE_SOLID,
            new Color([55,77,173,0.35]),
          new Color([125,125,125,0.35])
    // function toolbar
        function initToolbar() {
   alert("In initToolbar");
          tb = new Draw(map);
          tb.on("draw-end", addGraphic);
     // event delegation so a click handler is not
     // needed for each individual button
          on(dom.byId("info"), "click", function(evt) {
            if ( evt.target.id === "info" ) {
              return;
            var tool = evt.target.id.toLowerCase();
            map.disableMapNavigation();
            tb.activate(tool);
    // add graphic
        function addGraphic(evt) {
          //deactivate the toolbar and clear existing graphics
          tb.deactivate();
          app.map.enableMapNavigation();
          // figure out which symbol to use
          var symbol;
          if ( evt.geometry.type === "point" || evt.geometry.type === "multipoint") {
            symbol = markerSymbol;
          } else if ( evt.geometry.type === "line" || evt.geometry.type === "polyline") {
            symbol = lineSymbol;
          else {
            symbol = fillSymbol;
          app.map.graphics.add(new Graphic(evt.geometry, symbol));
KenBuja
MVP Esteemed Contributor
Two things.
I'm surprised it's not complaining about the fact that you're calling BufferTool function like this
 BufferTool();
with the function requiring the variable "map" to be passed into it.
Why are you adding in another map click listener with BufferClick?
     BufferClick = app.map.on("click", function(evt){           //define input buffer parameters           var params = new BufferParameters();           params.geometries  = [ evt.mapPoint ];           params.distances = [ 10 ];           params.unit = GeometryService.UNIT_STATUTE_MILE;           geometryService.buffer(params);         });
Why not set these parameters where you are initializing the event listener action2?
jaykapalczynski
Honored Contributor
This is the code from the IDENTIFY Button
    function initializeSidebar(map){
        var popup = map.infoWindow;
        //when the selection changes update the side panel to display the popup info for the
        //currently selected feature.
        connect.connect(popup, "onSelectionChange", function(){
            displayPopupContent(popup.getSelectedFeature());
        //when the selection is cleared remove the popup content from the side panel.
        connect.connect(popup, "onClearFeatures", function(){
           //dom.byId replaces dojo.byId
           //registry.byId replaces dijit.byId
           registry.byId("leftPane").set("content", "");
           domUtils.hide(dom.byId("pager"));
        //When features are associated with the map's info window update the sidebar with the new content.
        connect.connect(popup, "onSetFeatures", function(){
           dom.byId("featureCount").innerHTML = popup.features.length + " feature(s) selected";
       //enable navigation if more than one feature is selected
       popup.features.length > 1 ? domUtils.show(dom.byId("pager")) : domUtils.hide(dom.byId("pager"));
    function displayPopupContent(feature){
       if(feature){
           var content = feature.getContent();
           registry.byId("leftPane").set("content", content);
    function selectPrevious(){
       map.infoWindow.selectPrevious();
    function selectNext(){
       map.infoWindow.selectNext();
    function clearContent() {
jaykapalczynski
Honored Contributor
I am just not seeing where I can turn off the Buffer Tool....it just keeps selecting and running...
I have to click to button to activate it...there has to be a way to shut it off...
Anyone
KenBuja
In the BufferTool function, you add an event listener for the map click.
You could disconnect this event listener when the Identify Button is pressed (see the Event help topic) or use a variable to short circuit that click event. Something like
          if (CanRunBuffer) {
jaykapalczynski
Honored Contributor
I read through adn still a bit confused...I tried something like this
The Buffer code runs, but I still cant turn it off...am I close????
THANK YOU
  clearContent();
  connect.disconnect(BufferTool(app.map));
                clearContent();
  mapOnClick = connect.connect(map, "onClick", BufferTool(app.map))
jaykapalczynski
Honored Contributor
I tried these to unload the handler as...neither seemed to work
connect.disconnect(mapOnClick);
mapOnClick.remove();
KenBuja
THANK YOU
        clearContent();
                clearContent();
Have you tried
        clearContent();
and if you're using API 3.6 or higher, you should look at converting "connect.connect" to "on", since support for connect will be removed in Dojo 2.0
jaykapalczynski
Honored Contributor
I tried the below....I also tried defining mapOnClick outside the app.map.on
it just keeps running the Buffer code when i Click the map.
I am going to try and put a JSFiddle together.
            app.map.on("click", function () {
                clearContent();
            app.map.infoWindow.on("hide", clearContent);
            on(dom.byId("button1"), "click", function () {
                // I TRIED THIS
               // AND THIS
               var mapOnClick2 = connect.connect(app.map, "onClick", initializeSidebar(app.map))
  clearContent();
  // TRIED THIS
  // AND THIS
            on(dom.byId("button2"), "click", function () {
                clearContent();
  var mapOnClick = connect.connect(app.map, "onClick", BufferTool(app.map))
KenBuja
                clearContent();
                // I TRIED THIS
               // AND THIS
        clearContent();
        // TRIED THIS
        // AND THIS
                clearContent();
What do you have in the BufferTool function? Are you still adding the event
If so, you'll have to disconnect that if you click the Identify button.
jaykapalczynski
Honored Contributor
This is long and I thank you very much for your eyes on this....its driving me nuts...
        dialog.startup();
          25,
          dijitPopup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY
          12,
          return {
        grid.refresh();
    // function toolbar
          tb = new Draw(map);
              return;
            tb.activate(tool);
    // add graphic
          tb.deactivate();
          var symbol;
          else {
