Color Palette on graphics
2069
09-15-2014 09:14 AM
IbrahimHussein
Hello,
example - jsFiddle
Answer - jsFiddle
If you look at the example above, when you click a text field a color Palette comes up; is there an easy way to do this for a graphic (eclipse, triangle...) as well?
edit - Answer -
  var myPalette = new ColorPalette({
  palette: "7x10",
  onChange: function(val){
  if(grfx.geometry.type==="point")
  {return;}
  var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(val);
  var r = parseInt(result[1], 16)
  var g = parseInt(result[2], 16)
  var b = parseInt(result[3], 16)
  var symbol =  new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
  new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
  new Color([0,0,0]), 2),new Color([r,g,b,0.75]));
  grfx.setSymbol(symbol);
  }, "colorPal").startup();
On graphic click, I set the symbol to the color palette.
PaulCrickard1
You have the reference to ColorPalette so the textbox probably uses the dojo widget. You could hide a <div> with the colorpalette widget, then on an event (edit a marker) it becomes visible and the color chosen updates the graphic.
dijit.ColorPalette — The Dojo Toolkit - Reference Guide
IbrahimHussein
Thanks for the reply. I actually started to do that, that's why there's a reference to colorPalette. If  the reference is removed, it still shows up for the Text Box.
TimWitt2
Hey Ibrahim,
I have created this Javascript API - Advanced Draw widget
Maybe that can help you
Tim
IbrahimHussein
thanks, there were some cool stuff in there that I can see myself using.
