Collection View Source
1462
02-01-2011 12:26 PM
JayKappy
I am trying to Sort the results from a buffer using Collection View Source...I think I am on the right path here but cant seem to get the sort to perform or refresh the listbox.
In this case I am trying to sort by the Buffer Distance being created fro each selected feature found inside the buffer
Note: BUFFER_DISTANCE is not a field in the feature...its being created or set below in blue
Any quick thoughts?
    Private Sub QueryTask_ExecuteCompletedBuffer2(ByVal sender As Object, ByVal args As QueryEventArgs)
      ' Set up the collection View Source in order to Sort the results of the query by DISTANCE
                Dim cs As New CollectionViewSource
                cs.SortDescriptions.Add(New SortDescription("BUFFER_DISTANCE", ListSortDirection.Ascending))
                cs.Source = args.FeatureSet.Features
     ' Apply the sort to the listbox
                imageListBuffer.ItemsSource = cs.View
     ' refresh the listbox
                cs.View.Refresh()
        Dim featureSet As FeatureSet = args.FeatureSet
        imageListBuffer.ItemsSource = args.FeatureSet.Features
        ' Set the Buffer Variable for the Center Point of the buffer to a MAPPOINT not String to the variable being set
        ' in the GeometryService_BufferCompleted2...the Variable is globally define at the to of the code page
        Dim _XYLocationBuffer As MapPoint = Nothing
        _XYLocationBuffer = _XYLocation
        If args.FeatureSet.Features.Count < 1 Then
            MessageBox.Show("No features found")
            Return
        End If
        For Each selectedGraphic As Graphic In args.FeatureSet.Features
            selectedGraphic.Symbol = TryCast(LayoutRoot.Resources("DefaultMarkerSymbol"), ESRI.ArcGIS.Client.Symbols.Symbol)
            _resultsGraphicsLayer.Graphics.Add(selectedGraphic)
            ' Get the center point of each selected graphic found in the buffer
            Dim c As ESRI.ArcGIS.Client.Geometry.MapPoint = selectedGraphic.Geometry.Extent.GetCenter()
            ' Call the GetDistance Function...Set the Distance to the BUFFER_DISTANCE variable for each graphic, for display in the listbox
             selectedGraphic.Attributes("BUFFER_DISTANCE") = GetDistance(_XYLocationBuffer, c)
 Next selectedGraphic
    End Sub
JayKappy
JayKappy
no one out there has ever used CollectionViewSource to sort a listbox?  Just looking to see if I am doing this right or maybe even a hint towards some documentation....I have seen a few ways to do this but cant seem to get it to work...my post above seems to make sense but dont know if I need anything in the xaml file to tie it together.....
THanks
derekswingley1
This is the JavaScript API forum. Doubt you'll get much help with VB here...
MeConfused
AHHHHHH didnt see that thanks man
