Collapsing a DIV, then Reopen it?
3565
10-29-2015 01:48 PM
IanPeebles
Hello Everyone!  I was wondering if anyone has developed an application where you have a DIV that contains a legend, then you have an arrow or button that collapses it within an application?
If so, how can this be done?
Example:
The result would be more map space:
Any suggestions?  This will be the first time trying this out.  Thank you.
RickeyFight
Ian,
Like this:
City of Ashland Cemetery
TracySchloss
Honored Contributor
I've been looking into bootstrap styling.  This isn't setup as a tool, it's more checking the size of the screen and responding by collapsing the sidebar when the window is too small.  I have an 'everything must work on mobile' mandate.
I started with this:
Citizen Request
MichaelJenkins
Nice find Tracy Schloss!   Nice work Tom Wayson.
GISP
TracySchloss
Honored Contributor
Bootstrapmap is on ESRI's gitHub,   Bootstrap-map by itself only gets you part of the way, because the examples deal largely with just the map itself and not much on a complete interface.
I've had several instances where I've replaced Map with BootstrapMap, largely because it does a better job of resizing itself automatically, and you don't have to code listeners for that circumstance.  It might be the part of a solution for you, Ian, since once the sidebar is collapsed, you'll need the map to resize to fill out the frame.
I also got ideas from:
http://odoe.net/blog/dojo-bootstrap-with-arcgis-javascript-api/
Dojo Bootstrap Map
Using Bootstrap Map? You Might Not Need jQuery… | Tom Wayson
Esri/responsive-map-js · GitHub
