code": 498, "message": "Invalid token.
2846
01-02-2022 07:58 PM
naveenbesri
Hi All,
When i try to get arcgis portal users with below rest url in the code level. Im getting below error
function _verifyUserRole(username, token) { var xhttp = new XMLHttpRequest(); xhttp.onreadystatechange = () =>{ if(xhttp.readyState == XMLHttpRequest.DONE) { var jsonResponse = JSON.parse(xhttp.responseText); } }; xhttp.open("GET", "https://domainname/portal/sharing/rest/portals/0123456789ABCDEF/users?username="+username+"&f=pjson&referer=https://domainname&token=" + token, true);
xhttp.send(); }
"{"error": { "code": 498, "message": "Invalid token.", "details": [] }}"
But when i try to access the same url in the browser im getting response.
Could you please help me on this.
Thanks.
Kishore
@naveenbesri - try to send the token in the request header like below:
xhttp.setRequestHeader("token", token);
Regards,
Kishore
naveenbesri
Hi Kishore,
Now error is gone but we are not getting response and getting below
 getting cors error.
Kishore
@naveenbesri - try with following
xhttp.setRequestHeader('Access-Control-Allow-Origin','*');
Hope your server has CORS enabled...
Regards,
Kishore
naveenbesri
I tried this before but no luck getting same issue.
sigccil
Did you ever figure this out?
