Code problem IE 9 and up
10130
21
05-19-2015 06:15 AM
TimWitt2
Hey everybody,
I am having some issues with an application that I created in IE9 and higher.
Here is a link to my application: Advanced Draw
When I use it in Firefox, Google Chrome and IE 8 everything works fine. Once I switch to IE9 when I place a point, the point is displaced to the top-left. When I switch to IE10 the same happens and I have to click twice to place a point. I can't figure out what the issue could be.
If anybody has any inside!
Tim
ChrisSmith7
Honored Contributor
ChrisSmith7
Honored Contributor
Tim,
Try this:
        map.on("load", function () {
            toolbar = new Draw(map);
            toolbar.on("draw-end", addToMap);
  //toolbar.on("draw-complete", addMeas);
            editToolbar = new Edit(map);
            map.on("click", function (evt) {
                editToolbar.deactivate();
            createMapMenu();
            createGraphicsMenu();
            map.reposition();
            map.resize();
I added "reposition" and "resize" in your map onload event handler. This worked for me when I ran it in IE's debugger.
TimWitt2
Chris,
thejus's solution of removing the margin works in IE10 compatibility view but not in IE10 or IE9.
I tried your approach but no luck. Does it work here for you ( I have updated the code to include your solution.
Advanced Draw
ChrisSmith7
Honored Contributor
This works for me now in IE11. I tried it using IE 8/9/10 emulation as well, and it works, although I still need to click twice for the point to show. I don't have a "real" instance of IE <11 to test, though...
Try clearing your cache and restarting IE.
RobertScheitlin__GISP
Tim,
   I can report the same results as Chris. Works in IE 11 and IE 8/9/10 emulation as well. Although I don't get the click twice issue at all.
ChrisSmith7
Honored Contributor
I'm not getting that now, either - works on one click.
TimWitt2
I'll install IE11 and see if it is just a issue for my particular version.
PS: I am ready for IE to disappear
ChrisSmith7
Honored Contributor
Should be soon! At least in name... "Microsoft Edge."
TimWitt2
After installing IE11, the offset disappeared but the having to click twice issue is still there... very frustrating.
TomSellsted
Tim,
I found some event handling weirdness when creating my Measure Widget Measure Widget 1.1.1 for Web App Builder I had to use some special event handling to accommodate the differences between the versions of Internet Explorer.  My problem was more related to mouse-drag or mouse-move events, but maybe you are having a similar problem?
Regards,
Tom
