Clustering Feature Reduction using UniqueValueRenderer based on value from another field
884
09-23-2024 07:53 AM
LawrenceD
I am using Clustering Featured Reduction (ArcGIS Maps SDK 4.30) on a Feature Layer with UniqueValueRender for symbols for a category. By default, the API will symbolize the cluster based on the "predominant category". Where predominant seems to refer to the most frequent category in the cluster.
I want to use the symbol for the category with the highest value of a particular field in the cluster. As an example, my data contains a category called animals, and a particular cluster has 3 cats and a dog, the API assigns the cluster the symbol of a cat. In my data, I have an additional field, the price for each animal, and the dog has the highest cost of all animals, I would like to assign the cluster the symbol of a dog.
What I have tried:
Using UniqueValueRender value expression Arcade. From here I am able to access the cluster feature, summary stats (computed in the cluster configuration), but the attributes here do not contain the aggregated features. So I am not able to find out which of the cluster elements contain the highest value.
//Expects($Feature, '*')
  "attributes": {
    "aggregateId": "266.187",
    "cluster_count": 12,
    "max_price": 100.0001,
    "avg_price": 23.674746264166668,
    "count_animals": 12,
    "unique_id": "db4120ae-b6be-4cc2-b20e-0a10c388d829",
    "category": "Dog"
  "geometry": {
    "x": 108,
    "y": 178
  "centroid": {
    "x": 108,
    "y": 178
I have also tried creating a new category field from the aggregated features. The Arcade below will work fine to present this information in a pop up, so I would be able to find out the category with the highest value from $aggregatedFeatures
              label: 'Predominant category',
              type:'expression',
              expressionInfo: {
                expression: `
                      Expects($aggregatedFeatures, '*');
                    var statsFs = GroupBy($aggregatedFeatures,
                        { name: 'Type', expression: 'category'}
                        { name: 'MaxPrice', expression: 'price', statistic: 'MAX' }
                    var ordered = Top(OrderBy(statsFs, 'MaxPrice DESC'), 5);
                      // create an HTML ordered list as a string and return in a rich text element
                      var list = "<p>Top animals (Price)</p><ol>";
                      for (var cat in ordered){
                        list += \`<li>\${cat.Type} (\${Text(cat.MaxPrice)}) </li>\`
                      list += "</ol>";
                      return {
                        type: "text",
                        text: list
However trying the same approach in the fields definition does not work, as $aggregatedFeatures does not seem to exist.
          onStatisticExpression: {
            title: 'category',
            returnType: 'string',
            expression: `
                      //Works fine, but I have only access to a single feature not all cluster features
                      Expects($feature, '*')
                      //Error
                      return "Dog"
          ,statisticType: 'mode'
How can I achieve this? Thank you.
