close pane via BasemapToggle
3087
12
03-28-2014 07:13 AM
jaykapalczynski
Honored Contributor
I have a basemap toggle in my pane....I want to close the pane when the toggle is clicked.
I can do this with buttons no problem...but the toggle is giving me a problem
<div data-dojo-type="dijit/TitlePane" id="Tools"
 data-dojo-props="title:'Tools', closable:false, open:false">
 <div data-dojo-type="dijit/layout/ContentPane" style="width:200; ">
  <div class="toolbar"><span id="BasemapToggle" ></span></div>
                <div class="toolbar"><input type="button" class="myButton" id="button2" value="Finished" /></div>
 </div>
</div>
   on(dom.byId("BasemapToggle"), "click", function () {
         // CLOSE THE PANE WHEN Clicked
         dijit.byId("Tools").set('open',false); //Close
   var toggle = new BasemapToggle({
      map: app.map,
      basemap: "satellite",
      className: "customToggle"
    }, "BasemapToggle");
    toggle.startup();
CLOSE THE BUTTONS LIKE THIS
on(dom.byId("button2"), "click", function () {
jaykapalczynski
Honored Contributor
GOT IT....Thanks....for all your time...I move the "on(toggle"
After the "var Toggle"
      map: app.map,
 toggle.startup();
on(toggle, 'toggle', function(){
jaykapalczynski
Honored Contributor
thank you all for your help....things starting to make sense slowly.....Cheers
MattDriscoll
glad you got it working!
