Close Basemap Gallery On Selection
3793
9
11-07-2016 07:47 AM
LloydBronn
I have the basemaps gallery widget in my maps. I'd like the gallery to automatically close when a user chooses a basemap. I'm not sure if I need to specify this in basemapGallery.on "selection-change" event or in the TitlePane dijit itself. I looked at the API reference and I don't think the destroy() method is what I want.
RobertScheitlin__GISP
Lloyd,
   I normally use tp.toggle(); I would have to see more of your code.
Llyod,
   Yes if you are opening a TtilePane from some event and you want to close that pane then you need to attach to the selection-change and then close the pane from that event handler.
LloydBronn
I tried this, but it's not working.
basemapGallery.on("selection-change",function(){
var layer = map.getLayer(refLayerId);
if(layer){
map.removeLayer(layer);
dijit.byId("basemapGallery").set('open',false);
Lloyd,
LloydBronn
Tried this, but it didn't work.
var basemapGallery = new BasemapGallery({
 showArcGISBasemaps: true,
 map: map
 }, "basemapGallery");
 basemapGallery.startup();
 if(layer){
 }basemapGallery.toggle():
 basemapGallery.on("error", function(msg) {
 console.log("basemap gallery error: ", msg);
 basemapGallery.on("load", function(msg) {
 for (b=0;b<map.basemapLayerIds.length;b++){
 var lyr = map.getLayer(map.basemapLayerIds[b]);
 if(lyr._isRefLayer){
 refLayerId = lyr.id;
Also this
var tp =  dijit.byId("basemapGallery")
 if(layer){
 }tp.toggle():
Lloyd.
   Are you sure that basemapGallery and/or tp are not null that those vars are in scope?
LloydBronn
Gotcha. Something along these lines?
          var tp = dijit.byId("basemapGallery");
        if(layer && tp != null){
            tp.toggle();
Lloyd,
   Is "basemapGallery" the TitlePane or the basemap gallery widget? You need to get the titlepane not the basemap gallery widget.
LloydBronn
Ah, OK. My titlepane did not have a div ID, so I added one. That works, but only the first time I choose a new basemap. If I change it again, the titlepane stays open.
          var tp = dijit.byId("TitlePane");
            tp.toggle();
LloydBronn
Just needed an else{tp.toggle();}
