Clip operation Using ESRi Javascript API
819
09-22-2022 10:58 PM
Tarunvisvanadula1994
HI ,
How can we clip features  on map with polygon geometry using ESRI JavaScript API 3.x.
Thanks & Regards
Tarun
UndralBatsukh
Hi there,
You can use geometryEngine.clip() method. This method only allows you to clip geometries based on envelope. So not sure if it works for your case.
