Client side area and length measurement
2648
03-25-2011 12:11 AM
PauPérez_Puigcerver
Anybody knows how works the new API Enhancement for measure area and length at client side? There aren't any example.
Thanks
Pau Pérez
Conselleria de Medio Ambiente, Agua, Urbanismo y Vivienda
http://cartoweb.cma.gva.es
KellyHutchins
Esri Notable Contributor
We are working on adding a sample that shows how to use these, in the meantime the following code snippets might help:
GeodesicLengths:
map.graphics.add(new esri.Graphic(geometry, graphicSymbol));
//Since the map projection is web mercator, convert to lat/lon
var geographicGeometry = geometry;
//calculate geodesic length on client
var lengths = esri.geometry.geodesicLengths([geographicGeometry], esri.Units.KILOMETERS);
Geodesic Areas:
var geographicGeometries = [];
//if self intersecting, simplify using geometry service
if (esri.geometry.polygonSelfIntersecting(geometry)) {
  geometryService.simplify([geometry], function(simplifiedGeometries) {
    dojo.forEach(simplifiedGeometries, function(simplifiedGeometry, idx) {
      geographicGeometries.push(esri.geometry.webMercatorToGeographic(simplifiedGeometry));
    var areas = esri.geometry.geodesicAreas(geographicGeometries, esri.Units.ACRES);
    dojo.byId("result").innerHTML = "The area of the polygon is: " + areas[0] + " Acres";
else {
  geographicGeometries.push(esri.geometry.webMercatorToGeographic(geometry));
KellyHutchins
GeodesicLengths:
Geodesic Areas:
else {
PauPérez_Puigcerver
Thanks for the response.
