Click an icon/graphic and move it?
1600
11-08-2016 10:01 AM
DavidChrest
I know how to add an point icon/graphic to a map by clicking the map or with coordinates in code. I was wondering if that icon/graphic could then be moved across the map a bit and placed somewhere else with a mouse click-drag or something like that.
Thanks for any help provided.
RobertScheitlin__GISP
David,
 Sure you use the Edit class for that:
Edit | API Reference | ArcGIS API for JavaScript 3.18
To move a feature, once the Edit toolbar is activated with that feature, press down on the feature, drag it, then let go at the new location.
David,
DavidChrest
Ah yes, I see. Thanks so much.
