clearing the grid for OnDemandGrid
3204
12-04-2013 10:06 AM
DorothyMortenson
Hello,
I was using the sample at:
https://developers.arcgis.com/en/javascript/jssamples/fl_paging.html
There suppose to be a check if there are valid records, but it doesn't work in this sample.
I had added an input field and button to be able to do a query.  If the query is valid, I get results. If the query produces no results, the grid doesn't clear; it show the records from the previous successful records.
Anyone know how to clear the grid without clearing the query string?
Thank you.
Dorothy
JohnathanBarclay
Just set the store's data to an empty string then refresh the grid:
grid.store.setData("");
grid.refresh();
ChristianSailer2
Hi Johnathan
does this
  1. grid.store.setData("");
  2. grid.refresh();
still work?
I'm trying the same but the grid will not clear....
DorothyMortenson
Nice! Thank you.
