Clear Grid of Results
1515
07-17-2014 12:12 PM
jaykapalczynski
Honored Contributor
If I am populating my grid as such how to I clear it.....when I rerun my function to get new data in a new area the last results are there untill the code finishes running....I want that to clear first before running the code.
Function updateGrid(featureSet) {
   var data = arrayUtils.map(featureSet.features, function (entry, i) {
        return {
            SITENAME: entry.attributes.SITENAME,
            WATERBODY: entry.attributes.WATERBODY,
            ACCESSAREA: entry.attributes.ACCESSAREA,
   // If you use a store...
  dataStore = new Memory({
     "data": data,
     "idProperty": "id"
  gridNoColumnSets.set("store", dataStore);
  gridNoColumnSets.startup();
RobertScheitlin__GISP
Jay,
  If it is a dgrid you are talking about then you have to add an empty store to it before you go through your loop to add the new store.
function clearMyGrid()
     var emptyCells = { items: "" };
     var emptyStore = new dojo.data.ItemFileWriteStore({data: emptyCells});
     gridNoColumnSets.setStore(emptyStore);
Jay,
jaykapalczynski
Honored Contributor
Drove me a bit bonkers for a bit till I realized I was missing
"dojo/data/ItemFileWriteStore",
Thank you much for your help....very appreciated.
