Checking to see if dijit/form/CheckBox is checked
3273
09-23-2013 10:58 AM
by Anonymous User
Not applicable
Given:
function updateLayerVisibility() {
        var inputs = dojo.query(".list_item"), input;
        visible = [];
        for (var i=0, il=inputs.length; i<il; i++) {
          if (inputs.checked) {
            visible.push(inputs.value);
         //if there aren't any layers visible set the array value to = -1
        if(visible.length === 0){
          visible.push(-1);
  //alert(visible);
        layer.setVisibleLayers(visible);
--AND--
<input data-dojo-type="dijit/form/CheckBox" checked="checked" class='list_item' id='l0' value=0 onclick="app.updateLayerVisibility()">
The javascript code is not returning the checked status of the CheckBox. Ideas?
Thanks!
rGibson
KenBuja
MVP Esteemed Contributor
Instead of using dojo.query, try using dijit/registry/findWidgets instead.
KenBuja
by Anonymous User
Not applicable
Thanks for the quick reply, Ken. Is there a real-world example for this?
Thanks!
rGibson
by Anonymous User
Not applicable
So I guess a better question, given my code of:
<label class="chkLabel"><input data-dojo-type="dijit/form/CheckBox" checked="checked" class='list_item' id='l0' value=0 onclick="app.updateLayerVisibility()">Facilities</label>
what would be the formNode as prescribed in: var formWidgets = registry.findWidgets(formNode);
by Anonymous User
Not applicable
Yup, that worked....thanks for the tip
var inputs = registry.findWidgets(dom.byId("theDivContainingTheCheckBoxWidgets"));
