Changing rotation of WebStyleSymbol in 4.x API?
1154
03-07-2019 11:28 AM
LaurynasGedminas2
Found this read, not sure if its possible:Visualizing points with 3D symbols | ArcGIS API for JavaScript 4.10
Thank you,
Laurynas
BirajaNayak
If you are looking for sample, then it is here:
Visualize features with realistic WebStyleSymbols | ArcGIS API for JavaScript 4.10
Or else, please elaborate your requirement.
Biraja
ShuqiaoZhang
Hello, thank you for the answer! It helped me a lot.
In the sample page, the models are rendered based on the data provided by feature services. However, I cannot make it dynamically change based on user input. I would like to ask if it is possible to rotate the model by setting parameters on the client side?  Thank you!
