Changing css of identify task
1453
06-23-2014 06:23 AM
AndrewL
I have an Identify task and I am using this example: http://developers.arcgis.com/javascript/samples/find_popup/
Is it possible to change the opacity of the result? Currently fill-opacity is set to 0.25 and color is yellow. When I click inspect element:
path[Attributes Style] { fill: rgb(255, 255, 0); fill-opacity: 0.25; stroke: rgb(255, 0, 0); stroke-opacity: 1; stroke-width: 2px; stroke-linecap: butt; stroke-linejoin: miter; stroke-miterlimit: 4; stroke-dasharray: none; fill-rule: evenodd; }
I want the opacity to be 0.10.
I have added the following to my css, but it does not override the 0.25 opacity.
   path[Attributes Style] {   fill: rgb(255, 255, 0);   fill-opacity: 0.10;     }
I have added code to my css to change the size of the esri popup, so I am guessing it is possible. This works:
   .esriPopup .sizer {   width: 200px;    }
Thank you.
LuciHawkins
The results should be getting their symbols from:
var popup = new Popup({
          fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]))
        }, domConstruct.create("div"));
If you change the color, etc. there in the code you should see a difference.
Luci
LuciHawkins
Luci
AndrewL
Oh man I can't believe I didn't see that! Thank you. That worked.
LuciHawkins
Glad to be of some help 🙂
Luci
