Change the Order of Widgets in Widget Controller
1134
04-10-2025 04:53 AM
Gurunara
How to change the order of the widgets that's already placed into the widget controller in experience builder 1.14?
ShareUser
Esri Community Manager
Check the top bar and see if your layout is locked.
ShareUser
You can click and drag the icons to reorder them.
Gurunara
it does not allow this... either in design or runtime... am using widget controller, version 1.14... i had to go to server/apps/x/config.json to manually edit the order... (???)
ShareUser
