Change svg path on a symbol dynamically
1213
01-04-2024 03:18 PM
JimBambrough
I am try to update an svg path on a symbol dynamically AFTER it is rendered on the Map. I suspect I need to do some kind of refresh or something but I haven't had any luck so far. This is a sample of what I am using for the symbol. I am just trying to change the "path" attribute in the symbol object and have that new svg path show up on the Map:
        let symbol = {
          type: 'simple-marker',
          color: 'red',
          path: 'M150 0 L75 200 L225 200 Z',
        const polylineGraphic = new Graphic({
          geometry: {
            type: 'point',
            longitude: -113.074,
            latitude: 33.4484,
          symbol: symbol,
Tags (3)
