change search suggestions text
4576
04-01-2016 03:13 AM
MassimilianoSantini
hi all
is possible to change the suggestion text returned from the Search widjet?
I'm using only Esri World GeocodeServer as locator that return string like "address, region, state"
like this:
{"suggestions":[{"text":"Roma, Latium, Italy","ma ....
Region and state doesn't mach my italian languages (WHY???) so I've decided to remove it.
How can I modify the suggestion text?
thanks
Massimiliano
ChenLi2
hi Massimiliano,
I think you could use category to filter your suggest result, for example:
http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/suggest?f=json&text=redlands&maxS...
You could check the link here for details about possible values for the category:
Category filtering—ArcGIS REST API: World Geocoding Service | ArcGIS for Developers
MassimilianoSantini
Hi Chen,
thank for you answer but I badly explained my problem.
I already use the category "City" in my code:
sources.push({
                        locator: new Locator("//geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"),
                        singleLineFieldName: "SingleLine",
                        categories: ["City"],
                        outFields: ["*"],
                        countryCode: "IT",
                        maxResults: 3,
                        maxSuggestions: 6,
                        minCharacters: 3,
                        placeholder: "Località/Comune/Via/CAP"
but the suggests I get are written in mixed languages.
If I search for city "ROMA", I get, in the same suggest row, a text like this "ROMA, Latium, Italy".
Roma is in Italian, Latium, in English, Italy in English.
Is it possible to have all the three field in the same languge?
If not, is it possible to change/remove this field from the suggest?
Thanks again.,
Massimiliano
MassimilianoSantini
no suggestions?
