Change point location -V.4.0
1940
7
07-29-2016 09:03 AM
hebasaleh
i am using esri javascript v.4 ,if i have a services that push lat,long for point how can i change the point location on map without add and remove it ,also if i need to change  its symbol and attributes .
thejuskambi
If you are talking about, setGeometry and setSymbol methods that were there in 3.x (Graphic), you dont need them any more. In 4.x you can update the properties directly. I would suggest you to go through this Working with properties | ArcGIS API for JavaScript 4.0
hebasaleh
i tried to update the geometry as below but it didn't work
  var Layer =  this._service.map.layers.getItemAt(0);
       Layer.graphics.getItemAt(0).geometry.latitude += 0.001;
       Layer.graphics.getItemAt(0).geometry.longitude += 0.001;
assuming that i have only one graphic layer and only one graphic on it ,but nothing change.how can i write the path
on this._service.map.get("") if i have many graphic layers with many graphic
ReneRubalcava
There are a couple of ways you can update existing graphics on the Map in 4.0.
You can use the FeatureLayer#source or GraphicsLayer#graphics.
If you want to update a Graphic, you can do it by cloning the graphics, update the clone, remove the original and add the update.
Something like this.
var originalGraphic = featureLayer.source.getItemAt(2);
var graphic = originalGraphic.clone();
graphic.geometry = updatedGeometry;
graphic.symbol = updatedSymbol;
featureLayer.source.removeAt(2);
featurelayer.source.add(graphic);
That should work.
hebasaleh
thanks for your reply, i am using Graphic layer not feature layer,and the graphic layer doesn't contain Clone,so i am doing the following
this.point.latitude += 0.001;
        this.point.longitude += 0.001;
       var graphic =new Graphic({
           geometry: this.point,
           attributes: {
               index: this._pointIndex
           symbol: this.sym
       Layer.graphics.getItemAt(0);
       Layer.graphics.removeAt(0);
       Layer.graphics.add(graphic);
which i didn't like as i want to update the geometry without adding and removing the graphic again
thejuskambi
Rather than updating the latitude and longitude, I would suggest you could simply clone the geometry and try updating the Geometry of the graphic.
var graphic = Layer.graphics.getItemAt(0);
var newPoint = this.point.clone();
//updated the newPoint
graphic.geometry = newPoint;
hebasaleh
i tried the following
var graphicItem = this.graphicLayer1.graphics.find((x) => x.attributes["index"] == device.DeviceCode);
                var newPoint = graphicItem.geometry;
                var addpoint = newPoint.clone();
                addpoint.longitude = device.Location.Longitude;
                addpoint.latitude = device.Location.Latitude;
                graphicItem.geometry = addpoint;
but it didn't work .
ReneRubalcava
You have to remove and replace the entire graphic from the "graphics" collection for it to work.
