Change label of Delete button in Attribute inspector
4839
01-20-2014 06:24 AM
AleydisG__Pere
The thread title says it all.
I want to change the label of the Delete button in the Attribute inspector to 'Dismiss'. As that label has more sense in the context of my application.
Is this possible?
JonathanUihlein
Yep!
https://developers.arcgis.com/en/javascript/jssamples/ed_attribute_inspector.html
Starting at version 2.2, you can customize the fields in the attribute  inspector by specifying field information as part of the layer infos  object.
As for the button:
dijit.byId("dijit_form_Button_0").set("label", "Dismiss");
*edit
"dijit_form_Button_0" is the widgetid; grabbed from the demo above using firebug but you can always set your own.
RowenaTansley1
How do you set the ID of the delete button in the attribute inspector? Thanks!
AleydisG__Pere
My application is similar to this other sample where your suggestion won't work as a new button is created each time I click on the map to add a new feature.
AleydisG__Pere
As I use 2 attribute inspectors (one is read only). Every time I query a feature in the map a new attribute inspector widget is created (esri_dijit_AttributeInspector_0, esri_dijit_AttributeInspector_1, esri_dijit_AttributeInspector_2,....) and therefore I can't change its Delete button label, because its id is different every time too (dijit_form_Button_0, dijit_form_Button_8, dijit_form_Button_16,...).
I've tried destroying the attr. inspector widget with the destroy() method so every time it's recreated it has the same id, i.e. esri_dijit_AttributeInspector_0, (and also the buttons in it) but to no avail. I've also tried with this, but it doesn't work:
dijit.registry.byId("esri_dijit_AttributeInspector_0").destroy();
dijit.registry.remove("esri_dijit_AttributeInspector_0");
I don't know if this code behavior should be avoided. Do I only have an attribute inspector widget each time, only that with different label, or am I keeping each one created? ?_?
I'd like to find it out but meanwhile what I'm doing is hide the widget's 'Detele' button and create my own 'Dismiss' button. Any code improvement is welcome. 😉
Here's my code:
    var layerInfos = [{
      'featureLayer': featLayer,
      'isEditable': true,
      'showAttachments':false,
      'showDeleteButton':false,
      'disableAttributeUpdate':false,
      'disableGeometryUpdate': true
    attInspector = new esri.dijit.AttributeInspector({
      layerInfos: layerInfos
    }, dojo.create("div"));
    //selectedTemplate is the selected template picked by the user
    selectedTemplate.featureLayer.applyEdits([newGraphic], null, null, function() {
      var screenPoint = map.toScreen(getInfoWindowPositionPoint(newGraphic));
      map.infoWindow.setTitle("Incident about " + featLayer.name);
      map.infoWindow.setContent(attInspector.domNode);
      map.infoWindow.resize(260, 265);
      map.infoWindow.show(screenPoint, map.getInfoWindowAnchor(screenPoint));
      templatePicker.clearSelection();
    var DismissButton = new dijit.form.Button({ label: "Dismiss", "class": "deleteButton"});
    var DoneButton = new dijit.form.Button({ label: "Done", "class": "closeButton"});
    dojo.place(DismissButton.domNode,attInspector.deleteBtn.domNode, "before")
    dojo.place(DoneButton.domNode, DismissButton.domNode, "after");
    dojo.connect(attInspector, "onAttributeChange", function(feature, fieldName, newFieldValue) {
      feature.attributes[fieldName] = newFieldValue;
      feature.getLayer().applyEdits(null, [feature], null);
    DoneButton.on("click", function(){
      map.infoWindow.hide();
    DismissButton.on("click", function(){
      featLayer.applyEdits(null, null, [newGraphic]);
RowenaTansley1
Hi, did either of you find solutions to your problems? I am embarking down a similar path, modifying the attribute inspector, and creating and modifying buttons, curious if either of you have any tips for dealing with the attribute inspector and it's buttons? Thanks!
Also, I  did try the  sample posted above, and can't seem to place the save button correctly, it overlaps the delete button.
          var saveButton = new Button({ label: "Save", "class": "saveButton"},domConstruct.create("div"));
          domConstruct.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
