change fill color of esri.toolbars.Draw.EXTENT
1229
04-27-2010 06:12 AM
todddoerr
I want to change the fill color of the esri.toolbars.Draw.EXTENT box on the fly while it is being drawn on the map to show the user has reached some limit.  How do I do that?  Through Firebug I've found the node that contains the fill information and it looks like this:
<g id="map_graphics_layer" style="display: block;" transform="matrix(1, 0, 0, 1, 0, 0)"><rect fill="rgb(0, 0, 0)" fill-opacity="0.25" stroke="rgb(255, 0, 0)" stroke-opacity="1" stroke-width="2" stroke-linecap="butt" stroke-linejoin="miter" stroke-miterlimit="4" x="522" y="177" width="26" height="19" stroke-dasharray="none" dojoGfxStrokeStyle="solid" fill-rule="evenodd"/></g>
Programmatically, I'm able to  get that node using var extentBox = dojo.byId("map_graphics_layer").  And I can see the rect element but how do I edit the fill attribute?
Any help would be appreciated.
Todd
todddoerr
To anybody that is interested, I figured out how to change the fill color.  Here's my code.
// query for the rect element - not map_graphics_layer
var extentBoxElement = dojo.query('rect')[0];
// set fill to red
extentBox.setAttribute('fill',"rgb(255, 0, 0)");
This only works in FF though.  IE generates 'Error: Member not found' during setAttribute.  Inspection of the element in Firebug Lite shows there is no fill attribute and it's not obvious what attribute is being used for fill.
If anybody knows how to change the fill in IE it would be greatly appreciated.
Thanks.
Todd
DerekSwingley
I'm kinda late but how about esri.toolbars.Draw.setFillSymbol() when you cross some threshold?
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/draw.htm#setFillSymbol
todddoerr
Thank you.  That is a much better solution.  I just needed to read and understand the JS API better.
Thanks again.
