Change FeatureTable font size
4124
8
05-18-2022 06:04 AM
AdrianaPaese
Hello
Does anybody know how do I change the font-size of text in FeatureTable cells?
I am sending an image attached
Thank you in advance
RobertScheitlin__GISP
try this:
vaadin-grid-cell-content {
    font-size: .575rem !important;
To change the font size add this css rule to your deployed apps index.html:
.esri-grid .esri-grid__content {
    font-size: medium;
    --lumo-font-size-s: .875rem;
of course adjusting sizes to your liking. The font-size portion applies to the table column content and the --lumo-font-size-s pertains to the column header text.
AdrianaPaese
Hi Robert
Thank you very much for your reply
font-size: medium;
It worked well for the header but it didn´t change the font size within the
cells
Do you know what else may be happening?
Are these coming from
https://js.arcgis.com/4.23/esri/themes/light/main.css
or should I declare another css?
Thank you
Adriana
In my testing that css rule worked fine. Where are you placing this css rule? In which file?
AdrianaPaese
Hi Robert
The css rule you provided also works in the ESRI´s sample
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=widgets-featuretable-edi...
I replaced the feature layer and fieldConfigs in the above sample with my
own data and it also worked.
However, if I save the sample´s code as a html file and open it in the
browser the font-size definition has no effect on the text within the cells.
The same happens with my own code.
I don´t know why this is happening.
Thank you very much
try this:
AdrianaPaese
Yes, it works regardless of the browser minimum font-size settings
Thank you!
AdrianaPaese
It seems the problem has to do with the browser font-size appearance settings , which will override the css settings
AdrianaPaese
Thank you
