Change default localization
4707
01-19-2015 09:28 PM
GIMSlab
Does anyone know how to change default localization (English) to Russian? I tried dojoConfig, but nothing happens...
KishorGhatage
I believe,
1. You need to install Russian language pack which you can download from ArcGIS Customer care.
2. Go to Administrator > Advanced tab > change the display language > Save.
GIMSlab
I am talking about API use. And the thing is how to change localization in programming code?
JohnGrayson
Esri Alum
The Dojo framework (and thus the JS API) picks up the locale from the browser settings.  You can override the browser locale in the dojoConfig settings.  Please note: this setting is only read and used when the application first loads.
dojo.config (dojo/_base/config) — The Dojo Toolkit - Reference Guide
Internationalization (i18n) — The Dojo Toolkit - Reference Guide
