change default "No legend" text in Legend?
3133
10
08-16-2012 07:06 AM
deleted-user-ugCMpXci8bn5
Hello,
Is there a way I can change the default text 'No Legend' when there is nothing displayed in the legend (in my case, when all the layers are off)?  I would like to replace that text with a bit more informative message, and also format the text a bit so it isn't right on the top margin of the pane.
Thanks, Jason F.
KellyHutchins
Esri Notable Contributor
Yes you can modify the text that appears by setting a new value to this:
esri.bundle.widgets.legend.NLS_noLegend
See the following help topic for more details.
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/inside_bundle.html
KellyHutchins
Thank you,
I tried it within 'init' and within the layer checkbox function, and I get this message in Firebug:
TypeError: esri.bundle.widgets.legend is undefined
DO I need to add a require statement perhaps? I have already included "dojo.require("esri.dijit.Legend");"
KellyHutchins
This works for me:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <title>
      Create web map from id
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/esri/dijit/css/Popup.css">
    <style type="text/css">
       html,body {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Helvetica";
      #header {
        border:solid 1px #A8A8A8;
        overflow:hidden;
        background-color:#999;
        background: -webkit-gradient(linear, left top, left bottom, from(#fff), to(#C0C0C0));
        background: -moz-linear-gradient(top,  #fff,  #C0C0C0);
        height:65px;
        margin: 5px 5px;
      .roundedCorners {
        -o-border-radius:4px;
        -moz-border-radius:4px;
        -webkit-border-radius:4px;
        border-radius:4px;
      .shadow {
        -webkit-box-shadow:4px 4px 8px #adadad;
        -moz-box-shadow:4px 4px 8px #adadad;
        -o-box-shadow:4px 4px 8px #adadad;
      #title{
        padding-top:2px;
        padding-left:10px;
        color:#000;
        font-size:18pt;
        text-align:left;
        text-shadow: 0px 1px 0px #e5e5ee;
        font-weight:700;
      #subtitle {
        font-size:small;
        padding-left:40px;
        color:#000;
      #rightPane{
        background-color:#E8E8E8;
        border:solid 2px #B8B8B8;
        margin:5px;
        width:20%;
      #map {
        margin:5px;
        padding:0;
      .esriLegendServiceLabel{
        display:none;
   </style>
    <script type="text/javascript">
      var dojoConfig = {
        parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1">
    </script>
      dojo.require("dijit.dijit");
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
      dojo.require("esri.arcgis.utils");
      dojo.require("esri.dijit.Scalebar");
      var map;
      function init() {
        esri.bundle.widgets.legend.NLS_noLegend = 'No Legend Available';
        var mapDeferred = esri.arcgis.utils.createMap("92309d85b34342de8514caefa3df56a5", "map", {
          mapOptions: {
            slider: true,
            nav:false
        mapDeferred.addCallback(function(response) {
          dojo.byId("title").innerHTML = response.itemInfo.item.title;
          dojo.byId("subtitle").innerHTML = response.itemInfo.item.snippet;
          map = response.map;
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
          //add the legend
          var layers = response.itemInfo.itemData.operationalLayers;
          if(map.loaded){
            initMap(layers);
          else{
          dojo.connect(map,"onLoad",function(){
            initMap(layers);
        mapDeferred.addErrback(function(error) {
          console.log("Map creation failed: ", dojo.toJson(error));
      function initMap(layers){
       //add chrome theme for popup
        dojo.addClass(map.infoWindow.domNode, "chrome");
       //add a scalebar
        var scalebar = new esri.dijit.Scalebar({
          map:map,
          scalebarUnit: 'english'
        //add a legend
        var layerInfo = dojo.map(layers, function(layer,index){
          return {layer:layer.layerObject,title:layer.title};
          var legendDijit = new esri.dijit.Legend({
            map:map,
            layerInfos:layerInfo
          },"legend");
          legendDijit.startup();
      //show map on load
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
      <div id="header" class="shadow roundedCorners" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'">
        <div id="title"></div>
        <div id="subtitle" > </div>
      </div>
      <div id="map" class="roundedCorners shadow" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div>
      <div id="rightPane" class="roundedCorners shadow" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'right'" >
        <div id="legend"></div>
      </div>
    </div>
  </body>
</html>
I'm not sure i can re-create this for my map.  Is there perhaps a difference in the functionality/runtime of this esri.bundle.widget when you use the ArcGIS utils functions that you use here?
I tried esri.bundle.widgets.legend.NLS_noLegend = 'No Legend Available'; as the first line in my init function but I get that same error.
Thanks, J
KellyHutchins
No there shouldn't be any difference. Can you try to create a simplified version of your app that shows the problem and post the code here?
derekswingley1
When is your init function called? It needs to be called by dojo.ready() to guarantee that all esri modules have loaded.
Do you mean I need to use dojo.ready with esri.bundle.widgets.legend.NLS_noLegend?
Right now init is called by dojo.addOnLoad(init).
I tried to change that call to 'dojo.ready(init) but I get the same error as I noted above.
I am working on a simplified, 1-file version of this code but it is tricky, there are lots of things going on and lots of dependencies.
derekswingley1
dojo.ready and dojo.addOnLoad are the same thing so it should be working.
If you can provide a simplified version of your code that shows the error we should be able to sort it out.
ok thanks..it will take me a bit to untangle all this code and make a working simplified version (plus we are using services on the development server, not sure how to work around that one) ...
in the meantime, do you think it would make a difference to run this line of code from inside a function (outside of init)?..so that all the requires are loaded first..?
