Change cursor on hover marks
3502
05-16-2022 09:29 AM
FredListy
Hello, I have this mark in a globe, it's just a circle, and I would like to change the cursor to pointer when hovering it. Can you help me?
        const geometryPolyne = new Polyline({
          paths,
        const symbolLine = new LineSymbol3D({
          symbolLayers: [
              type: "line",
              material: {
                color: "#EB995E",
              cap: "round",
              join: "round",
        const polylineGraphic = new Graphic({
          geometry: geometryPolyne,
          symbol: symbolLine,
        view.graphics.add(polylineGraphic);
UndralBatsukh
Hi there,
You can do something like the following where I am checking if the mouse is over the polyline.
 view.on("pointer-move", eventHandler);
function eventHandler(event) {
  // only include graphics from graphicslayer in the hitTest
  const opts = {
    include: graphicsLayer
  view.hitTest(event, opts).then((result)=>{
    if (result.results.length > 0) {
      result.results.forEach((r)=>{
        if (r.graphic.geometry.type === "polyline"){
          document.body.style.cursor = "pointer";
    } else {
      document.body.style.cursor = "auto";
UndralBatsukh
Hi there,
  const opts = {
    } else {
FredListy
It worked, but without opts object. Thanks!
I'm using pointGaphic as SimpleMarkerSymbol now. I tried to add SimpleMarkerSymbol or anything related to this in opts object and didn't work, so I deleted it and now it works.
EirikH
For anyone copying this code, please note that the pointer-move fires extremely often.
You should use some kind of throttling for this.
Example using lodash:
import { throttle } from 'lodash';
const pointerMoveHandler = (mapView: __esri.MapView) => {
  return throttle(
    (event: __esri.ViewPointerMoveEvent) => {
      const opts = {
        include: mapView.allLayerViews.find((lv) => lv.layer.id === "foo")
          ?.layer,
      void mapView.hitTest(event, opts).then((result) => {
        document.body.style.cursor = result.results?.length > 0 ? 'pointer' : 'auto';
    150,
mapView.on('pointer-move', pointerMoveHandler(mapView))
UndralBatsukh
Hi there,
Glad you got it working. Please feel free to mark this issue as resolved.
zjaffe_MapIT
@FredListy
@UndralBatsukh
I am looking to change the cursor in my ArcGIS Experience Builder Application. Where would I input the code above? (I do not have a developers background). Any tips or advice would be greatly appreciated.
Thanks!
