Change a geometry service to a geoprocessing service
3298
9
01-14-2014 09:14 PM
ArcGISG_I_S
Hi everyone,
I need your help in one problem that i am facing the last 3 days.
I create one web app using javascript that allow me to add point in the map and create buffer around each point (I used Geometry Service), now i should merge any buffer who intersect with the other one, so i create one model in model builder using Dissolve All and i publish it as a geoprocessing service.
That give me a url like: http://IP:6080/arcgis/rest/services/Service_Name/GPServer/Model_Name.
I tried to repalce the URL that i used for the geometry service by this URL but its not working.
Below is the Head code for the geometry service if you can help me to found the changes that i should do to have the result.
require(["dojo/dom",
          "dojo/dom-attr",
          "dojo/_base/array",
          "dojo/_base/Color",
          "dojo/parser",
          "esri/config",
          "esri/map",
          "esri/graphic",
          "esri/tasks/GeometryService",
          "esri/tasks/BufferParameters",
          "esri/toolbars/draw",
          "esri/symbols/SimpleMarkerSymbol",
          "esri/symbols/SimpleLineSymbol",
          "esri/symbols/SimpleFillSymbol",
          "dijit/layout/BorderContainer",
          "dijit/layout/ContentPane"],
    function(dom, domAttr, array, Color, parser, esriConfig, Map,
Graphic, GeometryService, BufferParameters, Draw, SimpleMarkerSymbol,
SimpleLineSymbol, SimpleFillSymbol)
      var map, geo, tb;
   parser.parse();
      map = new Map("map", {
        basemap: "streets",
        center: [-122.4, 37.785],
        zoom: 13,
esriConfig.defaults.io.proxyUrl = "/proxy";
    esriConfig.defaults.io.alwaysUseProxy = false;
geo = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
    map.on("load", initToolbar);
**  Initialize the drawing toolbar
function initToolbar(evtObj) {
      app.tb = new Draw(evtObj.map);
      app.tb.on("draw-end", drawPoint);
// Array where points are saved
var list = new Array();
    ** Draw point
function drawPoint(evtObj) {
      // Get the click geometry
   var geometry = evtObj.geometry;
   // Point symbol
      var symbol = new SimpleMarkerSymbol(
     SimpleMarkerSymbol.STYLE_SQUARE,
  10,
  new SimpleLineSymbol(
    SimpleLineSymbol.STYLE_SOLID,
    new Color([255,0,0]),
    1),
  new Color([0,255,0,0.25])
   // Add point to the map
      var graphic = new Graphic(geometry, symbol);
      app.map.graphics.add(graphic);
   // Store the point geometry
   list.push(geometry)
    **  Create buffer around points
function doBuffer() {
   // Stop drawing points
   app.tb.deactivate();
   // Show the zoom slider
      app.map.showZoomSlider();
      // Setup the buffer parameters
      var params = new BufferParameters();
      params.distances = [ dom.byId("distance").value ];
      params.bufferSpatialReference = new esri.SpatialReference({wkid: dom.byId("bufferSpatialReference").value});
      params.outSpatialReference = map.spatialReference;
      params.unit = GeometryService[dom.byId("unit").value];
   params.geometries = list;
   // Launch buffer calculation
      app.geo.buffer(params, showBuffer);
    **  Draw buffer on the map
    function showBuffer(geoms) {
   // Symbol of the buffer
      var symbol = new SimpleFillSymbol(
        SimpleFillSymbol.STYLE_SOLID,
          new Color([255,0,0,0.65]), 2
        new Color([255,0,0,0.35])
   // Add the buffer graphics to the map
   array.forEach(geoms, function(geometry) {
    app = {
      map: map,
      tb: tb,
      geo: geo,
   buffer: doBuffer
  ** Click on Foggy Zone button
  function foggyZoneClick(){
app.buffer();
  ** Click on Point button
  function pointClick(){
    app.tb.activate(esri.toolbars.Draw.POINT);
app.map.hideZoomSlider();
Any help is appreciate (Its really urgent 😞 )
JeffJacobson
When you post code on the forums be sure you use the
 tags to preserve your indentation, making the code easier for others to read.
    "dojo/dom-attr",
    "dojo/_base/array",
    "dojo/_base/Color",
    "dojo/parser",
    "esri/config",
    "esri/map",
    "esri/graphic",
function (dom, domAttr, array, Color, parser, esriConfig, Map,
    var map, geo, tb;
    parser.parse();
        basemap: "streets",
        zoom: 13
    var list = [];
     ** Draw point
        // Point symbol
        10,
        new Color([255, 0, 0]),
        1),
        new Color([0, 255, 0, 0.25]));
        list.push(geometry);
        params.distances = [dom.byId("distance").value];
        new Color([255, 0, 0, 0.65]), 2),
        new Color([255, 0, 0, 0.35]));
        array.forEach(geoms, function (geometry) {
    app = {
        map: map,
        tb: tb,
        geo: geo,
        buffer: doBuffer
function foggyZoneClick() {
    app.buffer();
function pointClick() {
ArcGISG_I_S
Ok jacobsj next time i will use it, so you can provide me with the an answer or any body can help 😞
RobertoPepato
I think that this happens because you're not accessing a GeometryService anymore (but still are using an instance of the GeometryService). You need a specialized task to do the job of calling and handling your custom GP service.
Take a look at the Geoprocessor class: https://developers.arcgis.com/en/javascript/jsapi/geoprocessor-amd.html
ArcGISG_I_S
Hi pepatosp,
Thanks for your feedback, it's exactly the problem i'am facing, even if i'am changing the geometry service and using geoprocessing service i'am still using an instance of the GeometryService.
I check the URL that you send me i found some classes that i change but still not working if you can provide me with more help i will be grateful.
Thanks a lot for your support
RobertoPepato
Hi pepatosp,
Could you post your full updated code here? This would help to diagnose your issue.
ArcGISG_I_S
Dear pepatosp,
bellow the full updated code:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
    on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Foggy Buffer Zone</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">
  <style>
     html, body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      overflow:hidden;
    #leftPane{
      color:#000;
      width:250px;
      padding-bottom:15px;
    #map{
      padding:0;
    .details{
      font-size:14px;
      font-weight:600;
      padding-bottom:20px;
  </style>
  <script src="http://js.arcgis.com/3.7/"></script>
  <script>
          "dojo/dom-attr",
          "dojo/_base/array",
          "dojo/_base/Color",
          "dojo/parser",
          "esri/config",
          "esri/map",
          "esri/graphic",
    "esri/tasks/Geoprocessor",
    "esri/tasks/FeatureSet",
          "esri/tasks/LinearUnit",
 Graphic, Geoprocessor, FeatureSet, LinearUnit, Draw,
 SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol)
      var map, gp, tb;
parser.parse();
        basemap: "streets",
        zoom: 13,
 gp = new Geoprocessor("http://localhost:6080/arcgis/rest/services/SFFoggyZone/GPServer/Model");
   //gp.setOutputSpatialReference({
              //wkid: 32612
    ** Draw point
   // Point symbol
  10,
    1),
   list.push(geometry)
     // var params = new BufferParameters();
     // params.distances = [ dom.byId("distance").value ];
    //  params.bufferSpatialReference = new esri.SpatialReference({wkid: dom.byId("bufferSpatialReference").value});
     // params.outSpatialReference = map.spatialReference;
     // params.unit = GeometryService[dom.byId("unit").value];
 //  params.geometries = list;
   var features = [];
     // features.push(graphic);
   var featureSet = new FeatureSet();
      featureSet.features = features;
   var distances = new LinearUnit();
      distances.distance = [ dom.byId("Dis").value ];
      distances.units = [dom.byId("unit").value];
  // var bufferSpatialReference = new gp.setOutputSpatialReference({wkid: dom.byId("bufferSpatialReference").value});
   var params = {
              "Foggy_Points":FeatureSet,
     "Boundary_Polygons":FeatureSet,
              "Buffer_Distance": distances,
     "bufferSpatialReference": dom.byId("bufferSpatialReference").value
     // app.geo.buffer(params, showBuffer);
   gp.execute(params, showBuffer);
    app = {
      map: map,
      tb: tb,
      geo: geo,
   buffer: doBuffer
 app.buffer();
  ** Click on Clear Graphics button
  function clearGraphicsClick(){
    app.map.graphics.clear();
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit.layout.BorderContainer"
       data-dojo-props="gutters:'true', design:'sidebar'"
       style="width:100%;height:100%;">
    <div id="map"
         data-dojo-type="dijit.layout.ContentPane"
         data-dojo-props="region:'center'">
    </div>
    <div id="leftPane"
         data-dojo-props="region:'left'">
   <div><b>Foggy Zone Parameters</b></div>
      Spatial Reference WKID: <input type="text" id="bufferSpatialReference" size="5" value="32612" /><br />
      Distance: <input type="text" id="Dis" size="5" value="1" />
      <select id="unit" style="width:100px;">
   <option value="UNIT_KILOMETER">Kilometers</option>
   <option value="UNIT_METER">Meters</option>
        <option value="UNIT_STATUTE_MILE">Miles</option>
      </select><br />
<hr />
      <div class="details">Please enter points of the Foggy Zone</div>
      <button data-dojo-type="dijit.form.Button" onclick="pointClick();">Report Fog</button>
    <button id="point" data-dojo-type="dijit.form.Button" onclick="foggyZoneClick();">Foggy Zone</button>
      <button data-dojo-type="dijit.form.Button" type="button" onclick="clearGraphicsClick();">Clear Graphics</button>
<br />
    </div>
  </div>
</body>
</html>
RobertoPepato
Could you also post the error message on your javascript console? As you're running a local GP service, I can't run it here to reproduce and analyze your issue.
I'm curious about one thing: Does your GP service do some specialized buffer operation?
ArcGISG_I_S
Dear pepatosp,
I' am using a buffer service attached you will find a print screen of the model that i am using that will help you.
Foggy Point: are the points that we should add to the map
Boundary Polygon: is the limit of the area in order to be sure that our buffer zone not across this area.
Buffer distance: the value of the size of the buffer.
Thx a lop for your support.
[ATTACH=CONFIG]30648[/ATTACH]
ArcGISG_I_S
Good morning,
Any suggestions to help!! i'am still facing the same problem ?!
Thanks.
