Cesium load i3s layer example
4225
06-24-2021 05:20 AM
Zhitao
Hello everyone.
I found a video shared by Esri Event. I am very interested in Cesium loading I3S layers at 19:43. I checked the CesiumJS API. I haven’t found the Cesium.I3sDatasource method in the video yet. I noticed that the version of Cesium used in the video is built locally. Where can I get this version in the video for testing?  Or is there any plan to open source and merge into Cesium?
https://youtu.be/0C2fvQXqODQ?t=1195
In this session we'll see various demos and use cases that illustrate I3S usage in open source frameworks including Vis.gl, pdal.io, Cesium as well as the usage of I3S content in deep learning context. The demo will show case both content creation as well as consumption aspects of the various ...
Tim_McGinnes
Tim_McGinnes
Looks like there is a pull request in the CesiumGS GitHub repo for this:
https://github.com/CesiumGS/cesium/pull/9634
The I3SDatasource code is here:
https://github.com/Tamrat-B/cesium/blob/cesium_i3s_support/Source/DataSources/I3SDataSource.js
Zhitao
Thank You @Tim_McGinnes
