centerandzoom & onClick event mappoint spatialreference null
3242
11
09-17-2010 08:07 AM
GlenRhea
I have a "zoom to county" drop down that uses centerandzoom which works great however all my onclick events fail when I use the zoom because mappoint spatialreference is null until I pan the map. Once I pan the map all my onclick events work fine.
This issue also affects another function that uses centerandzoom but displays a layer instead. The layer doesn't show up until I pan a little.
There is too much code to post so here is a link to the app:
http://dev.geostor.arkansas.gov/G6/Viewer.html
All my code is in http://dev.geostor.arkansas.gov/G6/js/Viewer.js and the two functions I'm referring to are zoomCounty() and xyZoom()
Thanks for your time,
Glen
GlenRhea
Ahhh I see what you're saying now. Because I didn't define the spatial reference on the point when I used centerandzoom the spatial reference was null until I panned some.
Sigh. I'm usually pretty good about RTFM'ing too 😞
Thanks again for all your time.
Glen
derekswingley1
No problem, my pleasure to help.
