centerandzoom & onClick event mappoint spatialreference null
3251
11
09-17-2010 08:07 AM
GlenRhea
I have a "zoom to county" drop down that uses centerandzoom which works great however all my onclick events fail when I use the zoom because mappoint spatialreference is null until I pan the map. Once I pan the map all my onclick events work fine.
This issue also affects another function that uses centerandzoom but displays a layer instead. The layer doesn't show up until I pan a little.
There is too much code to post so here is a link to the app:
http://dev.geostor.arkansas.gov/G6/Viewer.html
All my code is in http://dev.geostor.arkansas.gov/G6/js/Viewer.js and the two functions I'm referring to are zoomCounty() and xyZoom()
Thanks for your time,
Glen
derekswingley1
Hi Glen,
I took a look but I'm not quite clear on what specifically is failing. Can you elaborate?
Thanks.
derekswingley1
OK, I see what you're describing. I think this is where you're spatialReference is getting screwed up:
var pnt = new esri.geometry.Point(Number(temp[0]),Number(temp[1],new esri.SpatialReference({ wkid: 26915})));
You've got a paren out of place. Add a closing paren after your second Number() function call on line 598 and take one off of the end of that line in viewer.js.
GlenRhea
That's what I tried to do but I couldn't find any way to populate that for a mappoint. I may go ahead and call support but I usually figure it out right after I call them 😞
derekswingley1
Edited my previous post...just posting here so you get a notification that the thread was updated.
GlenRhea
Nice catch! Yep that fixed it, been looking for that one (off and on) for awhile.
I appreciate your help!
Glen
GlenRhea
I know it's working now but IMO it shouldn't send a null spatial reference just because I use centerandzoom...
ESRI, you listening?
derekswingley1
Glad to help!
I'm guessing someone from Esri will see this but what do you want them to do? I mean, the problem was a syntax error in your code. Granted, it resulted in the API acting kind of strange but the source of the issue was your code. Maybe you should still contact support if you think this is a legitimate bug.
GlenRhea
I put the spatial references in there to make it work because the events were showing null after I used centerandzoom.
I don't think you should have to manually re-define the spatial reference just because you use centerandzoom, it should still be defined and not null.
In my mind, that's a bug...
derekswingley1
Here's the doc for esri.geometry.Point:  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/point.htm
Spatial reference is listed as required...
