center map on layer extent
6949
10
01-13-2014 08:23 AM
MaxDemars
Hello,
Im new to the arcgis javascript api and I cant find answer to my question. esri.map seems to only have centerAt(mapPoint) method but how to center the map on a ArcGISDynamicMapServiceLayer extent not on a point?
Thank you
KenBuja
MVP Esteemed Contributor
Try this instead
require(["esri/map", "dojo/domReady!", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/SpatialReference",], function(Map) {     var layer1 = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services/carte1/MapServer");     map = new Map("maptest1");     map.addLayers([layer1]);      map.on("layers-add-result", function(){         var extent = layer1.fullExtent;         map.setExtent(extent);         alert(extent.xmax);     }); });
JohnGravois
welcome to the forums burton!
if you have a reference to an extent object, you could find its center using the method extent.getCenter()
afterward, you could pass the point which is returned to map.centerAt()
MaxDemars
Allright, I understand that, the map center is moved to the center of the layer, but the map is not zoomed to the layer extent.
JohnGravois
you probably want to be calling map.setExtent().
MaxDemars
Thank you for your help jgravois,
The problem I encounter is that the layer I am trying to zoom to, an esri.layers.ArcGISDynamicMapServiceLayer instance, do not have a getExtent() method and the fullExtent property is empty. By default the map extent is set in order that we only see a part of the layer, but not its entire extent.
KenBuja
You may be checking the fullExtent property before the layer is ready. Try getting the full extent in the layer's load event.
MaxDemars
Hi kenbuja,
I dont know what is wrong here... fullExtent is always empty
[INDENT]           var layer1 = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services/carte1/MapServer");
           alert(extent) // empty box is popped
           map.setExtent(extent);[/INDENT]
KenBuja
Try this instead
JohnGravois
as ken said, the call to the service itself is asynchronous so you have to wait until you know the layer has actually completed loading.
map.addLayer(dynamicMapServiceLayer);
console.log(dynamicMapServiceLayer.fullExtent); //this will be null
dynamicMapServiceLayer.on("load", function(evt) {
  console.log(evt.layer.fullExtent);   //this will be populated
MaxDemars
Try this instead
        alert(extent.xmax);
Thank you for your help kenbuja, this is working correctly. I will have to study events carefully as it seems its the base of this API.
