Capture Zoomto button's Click from map.infowindow
1491
02-12-2014 08:47 AM
VikramS
All,
Can anyone please show me how to capture the zoom-to click event which is available in the map.info window ?
ManishkumarPatel
Hi Vikram,
You can disconnect the ESRI Zoom To function like this:
dojo.disconnect(map.infoWindow._eventConnections[4]);
This assume your var map = esri.Map(). The the fifth element in the _eventConnections array is the zoom to event.
Then you can attach your own events to the Zoom To with jQuery or dojo:
// Add custom zoom To
$('.action.zoomTo').click(function () { alert('First!'); });
$('.action.zoomTo').click(function () { alert('Second!'); });
It appears that the new connection can only be made after the an InfoTemplate is instantiated.
Best Regards,
Manish
VikramS
Thanks Manish . Also I had another question . Is it possible to capture the next feature on click and previous feature on click event in map.infoWindow .
IS it possible to capture it ?
ManishkumarPatel
You are welcome. Please help to mark this thread as answered if your issue has been resolved 🙂
Also regarding the next and previous feature. Do you mean to select the feature on the map which corresponds to the next record in the attribute.
I am sorry I didnt quite get what you mean.
Please help to provide some detailed scenario.
Thanks
