Cannot update a component (`AppContextProvider`) while rendering a different component (`App`)
1571
02-12-2023 06:44 PM
mnoel2
I'm using Rene Rubacalva example in jsapi-esm-react/AppContext.js at main · odoe/jsapi-esm-react · GitHub
I'm getting the following error:
Warning: Cannot update a component (`AppContextProvider`) while rendering a different component (`App`). To locate the bad setState() call inside `App`, follow the stack trace as described in
//code
//AppContext
import React, { createContext, useEffect, useReducer, useRef } from 'react';
export const AppContext = createContext();
//const elRef = useRef(null);
const initialState = {
    showMap: false,
    container: null,
function reducer(state, { type, payload }) {
    switch (type) {
        case 'SHOW_MAP':
            return {
                ...state,
                showMap: payload.showMap,
                container: payload.container,
        default:
            return state;
const AppContextProvider = (props) => {
    const [state, dispatch] = useReducer(reducer, initialState);
    const value = { state, dispatch };
    useEffect(() => {
    useEffect(() => {
        const loadMap = async () => {
                //const map = await import("./data/webmap")
                const { initialize } = await import('./data/webmap');
                //map.initialize()
                const { container} = state;
                await initialize(container);
        if (state.showMap) {
            loadMap();
    }, [state]);
    return <AppContext.Provider value={value}>{props.children}</AppContext.Provider>;
export default AppContextProvider;
//App.jsx
import { AppContext } from './AppContext ';
function App() {
const { state, dispatch } = useContext(AppContext);
const mapDiv = useRef(null);
  useEffect(() => {
    if (mapDiv.current) {
       * Initialize application
      const info = new OAuthInfo({
      appId: "abc",
      portalUrl: "https://<server>/portal/",
      popup: false,
      esriId.registerOAuthInfos([info]);
      esriConfig.portalUrl = "https://<server>/portal";
    esriId.checkSignInStatus(esriConfig.portalUrl + "/sharing").then(
      function () {
          DisplayForm();
      function (error) {
          console.log(error);
      esriId.getCredential(esriConfig.portalUrl + "/sharing").then(function (creds) {
        console.log(creds);
      esriId.destroyCredentials();
      debugger;
      DisplayForm();
console.log("map is loading");
  return (
    <div>
    <MainContainer maxWidth={state.showMap ? 'lg' : 'sm'}>
      <div className="mapDiv" ref={mapDiv} style={{ width:'100vw', height:"100vh"}}>
       {state.showMap ? (
                          dispatch({
                              type: 'SHOW_MAP',
                              payload: {
                                  showMap: true,
                                  container: mapDiv.current,
  </div>
      </MainContainer>
      </div>
export default App;
