I'm using the arcgis-features map component in a react application and I'm able to add an action button in the header. Now the problem is that the "onarcgisTriggerAction" event handler is never fired when I click on the action button. Is this a bug?
Here's my code :
const [actionDetacherInformations] = useState(new Collection([new ActionButton({icon:"popup", title:"Détacher", id:"detacher",type:"button"})]));
<arcgis-features
onarcgisTriggerAction={e => {
if(e.detail.action.id === "detacher"){
setPopupDockEnabled(false);
headerActions={actionDetacherInformations}
referenceElement={mapId}>
Hi @FrValade1 -
Right now, the `trigger-action` event only covers the actions in the action bar. This doesn't include the header actions. We will look into updating the `trigger-action` event to fire when `headerActions` are triggered as well.
Could you provide more information on your use case for adding a custom headerAction? Looks like you may be creating a dock button for the Features component?
I wanted to add a dock button to the header and I thought that the `trigger-action` event would be triggered since the headerActions property was available in the component. Also, I noticed that once I close the features component by using the default close button, I can't open or fetch features anymore because of an error :
const featuresHandle = reactiveUtils.on(
() => arcgisMapRef.current?.view,
"click",
async (event) => {
if(popupDockEnabled){
const { screenPoint } = event;
const features = await featuresRef.current?.fetchFeatures(screenPoint);
const graphics = await features?.allGraphicsPromise;
setPopupAucunResultat(graphics?.length === 0);
if (featuresRef.current) {
featuresRef.current.features = graphics ?? [];
setPanneauSelectionne("information");
setPanneauGaucheFerme(false);
Finally, I resolved my problem by hiding the header with the hideHeading and hideCloseButton properties and wrapping the arcgis-features component inside a calcite-flow-item with a header and custom actions. I replaced the close button with a custom action that change the closed property on the component. By doing it this way, there was no more problems with the fetchFeatures promise.
<calcite-flow>
<calcite-flow-item closed={!popupDockEnabled || popupAucunResultat} selected heading={titreFeatures ?? undefined}>
<calcite-action text="Afficher dans la carte" title="Afficher dans la carte" slot="header-actions-end" icon="popup"
onClick={async () => {
await arcgisMapRef.current?.view.openPopup({ features: featuresRef.current?.features })
if (arcgisMapRef.current?.view.popup) {
while (arcgisMapRef.current.view.popup.selectedFeatureIndex !== featuresRef.current?.selectedFeatureIndex) {
arcgisMapRef.current.view.popup.next();
}> </calcite-action>
<calcite-action text="Fermer" title="Fermer" slot="header-actions-end" icon="x"
onClick={() => {
setPopupAucunResultat(true);
<arcgis-features ref={featuresRef}
onarcgisReady={() => setFeaturesRefReady(true)}
hideHeading
hideCloseButton
</arcgis-features>
</calcite-flow-item>
</calcite-flow>
