Cannot set properties of undefined (setting 'OBJECTID')
2513
04-02-2024 03:45 AM
cadgism
Hi
1. I am creating a new feature layer based on a spatial query. The query is fine. It selects the features  can see it in console.log
2. Created a new feature layer out of this queried results, also works perfect   can see the feature layer attributes in console too
3. When I am trying to add this layer to the map,  it produces an error  "Cannot set properties of undefined (setting 'OBJECTID')" and stops. Any help please
query.executeQueryJSON(searchUrl, queryObj).then(function (results) {
                    console.log(results.features.length);
                    //new feature layer to put selected features
                    selSketch = new FeatureLayer({ id: "selSketchLayer", outfields:"[*]" });
                    if (results.features.length > 999) {
                        alert("Max Record Count more than 1000. Please Select smaller area !!!");
                        deleteSketch();
                        return;
                    skfeatures = results.features;
                    var fields = results.fields;
                    selSketch.source = results.features;
                    selSketch.fields = fields;
                    selSketch.objectIdField = "OBJECTID";
                    selSketch.renderer = selSketchRenderer;
                    app.map.remove(Rerdlayer);
                    app.map.add(selSketch);
ErrorError
UndralBatsukh
Hi there,
When creating a client-side FeatureLayer, you must set the layer's schema correctly in the layer constructor especially if the source is not set. You cannot just set fields schema to wild card. You need to set the fields schema. Since you are creating a new client-side feature layer from query results, try changing your code as shown below and see if it fixes the problem.
const featureSet = results.features;
const layer = new FeatureLayer({
   source: featureSet,
   geometryType: featureSet.geometryType,
   objectIdField: "OBJECTID",
   fields: featureSet.fields,
   renderer: selSketchRenderer,
   //spatialReference: results.features[0].geometry.spatialReference
UndralBatsukh
Hi there,
   source: featureSet,
cadgism
Thank you, It Works!!!
