Cannot read property 'on' of null at Object.set (ExportWMSImageParameters.js:5)
4365
08-04-2017 06:26 AM
selcukcelik
possilel bug issues about WMSLayer (api:4.4)
I am getting error while trying to use WMSLayer.
ERROR: Cannot read property 'on' of null     at Object.set (ExportWMSImageParameters.js:5)
sample code from Sandbox: layers-wms
esriConfig.request.corsEnabledServers.push(
"mesonet.agron.iastate.edu");
layer = new WMSLayer({
// See http://mesonet.agron.iastate.edu/ogc/ for more WMS services from Iowa Environmental Mesonet (Iowa State University)
url: "https://mesonet.agron.iastate.edu/cgi-bin/wms/goes/conus_ir.cgi"
map = new Map({
//basemap: "dark-gray",
layers: [layer]
view = new MapView({
container: "viewDiv",
//center: [-123, 49],
//zoom: 5,
map: map
My code is smilar but it is typescript:
1- I am using for CORS:
or:
urlUtils.addProxyRule({
urlPrefix: "https://mesonet.agron.iastate.edu",
proxyUrl: "/proxy"
and rest of the code:
var wmsLayer: any = new WMSLayer();
wmsLayer.url = "https://mesonet.agron.iastate.edu/cgi-bin/wms/goes/conus_ir.cgi"
this.mapManagerService.map.add(wmsLayer);
by the way I cant reach WMSLayer "url" property so I define it "any" type (Arcgis js Api: 4.4)
Thanks.
KellyHutchins
Esri Notable Contributor
Looks like a bug in the typings that will be fixed at the next release.  To workaround the issue for now you can update the index.d.ts file to add url to the WMSLayerProperties.
  interface WMSLayerProperties extends LayerProperties, PortalLayerProperties {
    copyright?: string;
    customLayerParameters?: any;
    customParameters?: any;
    description?: string;
    featureInfoFormat?: string;
    featureInfoUrl?: string;
    fullExtents?: ExtentProperties[];
    imageFormat?: string;
    imageMaxHeight?: number;
    imageMaxWidth?: number;
    imageTransparency?: boolean;
    spatialReference?: SpatialReferenceProperties;
    spatialReferences?: number[];
    sublayers?: Collection | any[];
    version?: string;
    url?: string;
I added a TypeScript WMSLayer sample here that updates the WMSLayerProperties interface in app/updates.d.ts.
TSSamples_JSAPI/WMSLayer at master · kellyhutchins/TSSamples_JSAPI · GitHub
baskentedas
still a bug in 4.5?
thanks.
KellyHutchins
The issue is resolved in 4.5. I just tested with the sample and it works just fine without the uopdates.d.ts file included.
