Cannot get point graphic to draw
1231
10-11-2012 09:12 AM
CindyMeeker
I am revamping an old example and need help.  The example would allow the user to input a lat lon and would draw a graphic at that point and zoom to it.
I am trying to re-write it to take a lat lon passed in via the URL and draw a graphic and zoom to it.
**Yes, I know that you can do this on ArcGIS On-Line but I need it to open without the sidebar as this will be used within another application to track locations from a transaction table.** So I just need a simple map, no frills, that shows our property over imagery and adds a point and zooms to it.
The problem I am having is that my point is not drawing.  I am pretty sure that the lat lon is getting passed in correctly as the map is zooming to the right location.
This gets my lat lon from the URL:
                                var url = window.location;    var find = getLatLongFromURL(document.location.href);
    if (!!find)
     var param = find.split(" ");
     var lon = parseFloat(param[0]);
     var lat = parseFloat(param[1]);
     //alert("lat = "+ lat +", lon = " + lon);
     addPointToMap(lon,lat);
and the 2 pertinent functions are:
   function getLatLongFromURL(url)
    var urlObject = esri.urlToObject(url);
    if (urlObject.query && urlObject.query.find)
     return urlObject.query.find;
   }  //end getLatLongFromURL
   function addPointToMap(lon,lat)
    var point = new esri.geometry.Point(lon, lat, pfcMap.spatialReference);
    var symbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([0, 255, 0]));
    symbol.setSize(8);
    var graphic = new esri.Graphic(point, symbol);
    xMin = lon - 0.015;
    yMin = lat - 0.015;
    xMax = lon + 0.015;
    yMax = lat + 0.015;
      var newExtent = new esri.geometry.Extent();
      newExtent.xmin = xMin;
      newExtent.ymin = yMin;
      newExtent.xmax = xMax;
      newExtent.ymax = yMax;
      newExtent.spatialReference = new esri.SpatialReference({ wkid: 102100});
      pfcMap.setExtent(newExtent);
      pfcMap.graphics.add(graphic);
     }  //end addPointToMap
Any help here would be greatly appreciated.
KellyHutchins
Esri Notable Contributor
What's the spatial reference of your map? If it is web mercator you'll need to convert the lat/lon location from geographic to web mercator.  You can do this using the utility method esri.geometry.geographicToWebMercator.
Here's some test code that shows how this works, if I run this code using the following url param the map should zoom to New York
http://localhost/forum/zoomloc.html?location=-74.00,40.71
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
      <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title> World Street Map</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" />
    <style>
      html,body,#map,.map.container{
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2"></script>
      dojo.require("esri.map");
      var map;
      function init() {
        map = new esri.Map("map");
       //Add the world street map layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
        map.addLayer(basemap);
        dojo.connect(map, 'onLoad', function(theMap) {
           //get lon/lat from url
          var url = window.location.href;
          if (urlObject.query) {
            var location = urlObject.query.location || '';
            if(location){
              var vals = location.split(",");
              zoomToLocation(dojo.number.parse(vals[0]), dojo.number.parse(vals[1]));
          //resize the map when the browser resizes
          dojo.connect(window, 'resize', map,map.resize);
      function zoomToLocation(lon,lat){
        //convert point from geographic to web mercator since the map is in web mercator
        var point = new esri.geometry.Point(lon,lat, new esri.SpatialReference({ wkid: 4326 }));
        var wmpoint = esri.geometry.geographicToWebMercator(point);
        //add the graphic to the  map
        symbol.setSize(8);
        var graphic = new esri.Graphic(wmpoint,symbol);
        map.graphics.add(graphic);
        //zoom to the location
        var factor = 1;
        var zoomExtent =  new esri.geometry.Extent(
          wmpoint.x - factor,
          wmpoint.y - factor,
          wmpoint.x + factor,
          wmpoint.y + factor,
          wmpoint.SpatialReference
        map.setExtent(zoomExtent.expand(2));
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div id="map">
    </div>
  </body>
</html>
CindyMeeker
Thanks for the reply Kelly.
I had thought of this but my map zooms to the correct location, just doesn't draw the graphic.
