Cannot get a layer to appear on map
1187
01-06-2023 02:38 PM
JACOBSTEINBERG
This is my first time using the ArcGIS API for JavaScript. I'm running into a fairly elementary error. I cannot get a layer I have hosted on ArcGIS Online to appear on the map. Here is my code:
require([
    "esri/config",
    "esri/Map",
    "esri/layers/FeatureLayer",
    "esri/views/MapView"
], function (esriConfig, Map, MapView, FeatureLayer) {
    //Setting the API key
    esriConfig.apiKey = api key hidden
    const map = new Map({
        basemap: "arcgis-topographic"
    const view = new MapView({
        container: "viewDiv",
        map: map,
        extent: {
            xmin: -88.4407865369763,
            ymin: 44.2519512604157,
            xmax: -87.57033074655209,
            ymax: 44.58559644055305,
            spatialReference: 4326
    let one_year_high = new FeatureLayer({
        apiKey: api key hidden
    map.add(one_year_high);
This script produces the following error in my browser:
[esri.Map] #add() The item being added is not a Layer or a Promise that resolves to a Layer.
My layer can be found here: https://services.arcgis.com/HRPe58bUyBqyyiCt/ArcGIS/rest/services/1_year_high_lake_level/FeatureServ...
I can't figure out why it won't appear.
Thanks in advance.
ReneRubalcava
Esri Frequent Contributor
In your require and function, the MapView and FeatureLayer order are swapped. When using amd, the order matters.
ReneRubalcava
