cannot construct a PeUnit, no constructor in IDL
2410
08-18-2020 08:10 PM
DavidWilton
When using client side projection utility I was getting this error "cannot construct a PeUnit, no constructor in IDL". Google gave no results so I thought I'd log the solution here:
This causes the issue
var extprj = projection.project(new Extent(ext), this.map.spatialReference); // project ext
this.map.setExtent(extprj);
The solution is to create a new extent/clone it to pass into the projection
var extprj = projection.project(new Extent(ext),  new SpatialReference(this.map.spatialReference.wkid)); // project ext
If you don't any time attempts are made to clone the map spatial reference it causes errors.
I was using an older version of the API (3.24) so may have been resolved
Tags (1)
DavidWilton
Solution is to clone the map spatial reference:
DavidWilton
HaraldLund
You also have to clone the spatial reference for the geometry object you want to project. Referencing to the map's spatial reference for the geometry object will cause the same error.
