var template1 = new esri.InfoTemplate(); template1.setContent(SetFeatureLayer1PopupInfo); //call function to set the content template1.setTitle('Some generic title or another function'); var template2 = new esri.InfoTemplate(); template2.setContent(SetFeatureLayer2PopupInfo); //call function to set the content template2.setTitle('Some generic title or another function');
theFeatureLayer1 = new esri.layers.FeatureLayer("REST Url", { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, infoTemplate: template1, outFields: ["*"], visible: true }); theFeatureLayer2 = new esri.layers.FeatureLayer("REST Url", { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, infoTemplate: template2, outFields: ["*"], visible: true }); dojo.connect(theFeatureLayer1, "onClick", function(evt) { var query = new esri.tasks.Query(); query.geometry = pointToExtent(map,evt.mapPoint,10); var deferred = theFeatureLayer1.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW); map.infoWindow.resize(550,350); map.infoWindow.setFeatures([deferred]); map.infoWindow.show(evt.mapPoint); });
function SetFeatureLayer1PopupInfo(graphic) { fullAttr = graphic.attributes; someval = fullAttr.FIELDNAME; content = '<table><tr><td>Field Name:</td><td>' + someval + '</td><tr></table>'; return content; }
<!DOCTYPE html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Permit Locator</title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { padding:0; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.layers.FeatureLayer"); dojo.require("esri.dijit.Popup"); var map; var permits; var properties; function init() { var sfs = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([111, 0, 255]), 2), new dojo.Color([111, 0, 255, 0.15])); var popup = new esri.dijit.Popup({ fillSymbol: sfs }, dojo.create("div")); map = new esri.Map("map",{ basemap: "streets", center: [-84.183, 39.734], zoom: 13, infoWindow: popup }); dojo.addClass(map.infoWindow.domNode, "myTheme"); //Add all the permits and parcels to see on load var operationalLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://map.miamiconservancy.org:6080/arcgis/rest/services/MCDPropertiesGeoDB/MapServer", {"opacity":0.9}); map.addLayer(operationalLayer); //apply a popup template to the permits layer to format popup info var popupTemplate = new esri.dijit.PopupTemplate({ title: "{Permits.MASTERUSER.%PERMIT.ISSUEDTO}", fieldInfos: [{ fieldName: "Permits.MASTERUSER.%PERMIT.MCDNUM", label: 'Permit Number (MCDNUM):', visible: true }, { fieldName: "Permits.MASTERUSER.%PERMIT.LOCATION", label: "Location:", visible: true }] }); //apply a popup template to the MCD Parcels layer to format popup info var popupTemplateParcels = new esri.dijit.PopupTemplate({ title: "{MCDID}", fieldInfos: [{ fieldName: "MCDID", label: 'MCD ID:', visible: true }, { fieldName: "PARCELID", label: "Parcel ID:", visible: true }] }); //add the permits layer to the map as a feature layer in selection mode we'll use this layer to query and display the selected permits permits = new esri.layers.FeatureLayer("http://map.miamiconservancy.org:6080/arcgis/rest/services/MCDPropertiesJOINToSQL/MapServer/2", { outFields: ["*"], infoTemplate: popupTemplate, mode: esri.layers.FeatureLayer.MODE_SELECTION }); //add the Properties layer to the map as a feature layer in selection mode properties = new esri.layers.FeatureLayer("http://map.miamiconservancy.org:6080/arcgis/rest/services/MCDPropertiesJOINToSQL/MapServer/0", { outFields: ["*"], infoTemplate: popupTemplateParcels, mode: esri.layers.FeatureLayer.MODE_SELECTION }); permits.setSelectionSymbol(sfs); properties.setSelectionSymbol(sfs); //when users click on the map select the permit using the map point and update the url parameter dojo.connect(map, 'onClick', function (e) { var query = new esri.tasks.Query(); query.geometry = e.mapPoint; var deferred = permits.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (selection) { //update the url param if a permit was located if (selection.length > 0) { var mcdnum = selection[0].attributes["Permits.MASTERUSER.%PERMIT.MCDNUM"]; //Refresh the URL with the currently selected permit if (typeof history.pushState !== 'undefined') { window.history.pushState(null, null, "?mcdnum=" + selection[0].attributes["Permits.MASTERUSER.%PERMIT.MCDNUM"]); } } }); map.infoWindow.setFeatures([deferred]); map.infoWindow.show(e.mapPoint); }); dojo.connect(map, 'onLayersAddResult', function (result) { // Add a link into the InfoWindow Actions panel var emailLink = dojo.create("a", { "class": "action", "innerHTML": "Email Map", "href": "javascript:void(0);" }, dojo.query(".actionList", map.infoWindow.domNode)[0]); // Register a function to be called when the user clicks on // the above link dojo.connect(emailLink, "onclick", function (evt) { var feature = map.infoWindow.getSelectedFeature(); var url = window.location; var emailLink = "mailto:?subject=Permit Map of :" + feature.attributes["Permits.MASTERUSER.%PERMIT.MCDNUM"]+ "&body=Check out this permit: %0D%0A " + window.location; window.location.href = emailLink; }); //When users navigate through the history using the browser back/forward buttons select appropriate permit //https://developer.mozilla.org/en/DOM/Manipulating_the_browser_history window.onpopstate = function (event) { var mcdnum = getPermitFromUrl(document.location.href); if (mcdnum) { selectPermit(mcdnum); } else { permits.clearSelection(); map.infoWindow.hide(); } }; //if a mcdnum is specified in url param select that feature var mcdnum = getPermitFromUrl(document.location.href); selectPermit(mcdnum); }); map.addLayers([permits]); map.addLayers([properties]); } //extract the permit id from the url function getPermitFromUrl(url) { var urlObject = esri.urlToObject(url); if (urlObject.query && urlObject.query.mcdnum) { return urlObject.query.mcdnum; } else { return null; } } //select permit from the feature layer by creating a query to look for the input mcdnum id function selectPermit(mcdnum) { if (mcdnum) { var query = new esri.tasks.Query(); query.where = "Permits.MASTERUSER.%PERMIT.MCDNUM = " + mcdnum + ""; //query.where = "Permits.MASTERUSER.%PERMIT.MCDNUM = 2963"; var deferred = permits.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (selection) { var center = esri.graphicsExtent(selection).getCenter(); var extHandler = dojo.connect(map, 'onExtentChange', function () { dojo.disconnect(extHandler); //zoom to the center then display the popup map.infoWindow.setFeatures(selection); map.infoWindow.show(center); }); map.centerAt(center); }); } } dojo.ready(init); </script> </head> <body class="claro"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'" style="border:1px solid #000;padding:0;"></div> </div> </body> </html>
dojo.connect(permits, 'onClick', function (e) { var query = new esri.tasks.Query(); query.geometry = e.mapPoint; permits.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (selection) { //update the url param if a permit was located if (selection.length > 0) { var mcdnum = selection[0].attributes["Permits.MASTERUSER.%PERMIT.MCDNUM"]; //Refresh the URL with the currently selected permit if (typeof history.pushState !== 'undefined') { window.history.pushState(null, null, "?mcdnum=" + selection[0].attributes["Permits.MASTERUSER.%PERMIT.MCDNUM"]); } map.infoWindow.setFeatures(selection); map.infoWindow.show(e.mapPoint); } } }); // Now for the Properties layer dojo.connect(properties, 'onClick', function (e) { var query = new esri.tasks.Query(); query.geometry = e.mapPoint; map.infoWindow.setFeatures(selection); map.infoWindow.show(e.mapPoint); });
<!DOCTYPE html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Permit Locator</title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { padding:0; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.layers.FeatureLayer"); dojo.require("esri.dijit.Popup"); var map; var permits; var properties; function init() { var sfs = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([111, 0, 255]), 2), new dojo.Color([111, 0, 255, 0.15])); var popup = new esri.dijit.Popup({ fillSymbol: sfs }, dojo.create("div")); map = new esri.Map("map",{ basemap: "streets", center: [-84.183, 39.734], zoom: 13, infoWindow: popup }); dojo.addClass(map.infoWindow.domNode, "myTheme"); //Add all the permits and parcels to see on load var operationalLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://map.miamiconservancy.org:6080/arcgis/rest/services/MCDPropertiesGeoDB/MapServer", {"opacity":0.9}); map.addLayer(operationalLayer); //apply a popup template to the permits layer to format popup info var popupTemplate = new esri.dijit.PopupTemplate({ title: "{Permits.MASTERUSER.%PERMIT.ISSUEDTO}", fieldInfos: [{ fieldName: "Permits.MASTERUSER.%PERMIT.MCDNUM", label: 'Permit Number (MCDNUM):', visible: true }, { fieldName: "Permits.MASTERUSER.%PERMIT.LOCATION", label: "Location:", visible: true }] }); //apply a popup template to the MCD Parcels layer to format popup info var popupTemplateParcels = new esri.dijit.PopupTemplate({ title: "{MCDID}", fieldInfos: [{ fieldName: "MCDID", label: 'MCD ID:', visible: true }, { fieldName: "PARCELID", label: "Parcel ID:", visible: true }] }); //add the permits layer to the map as a feature layer in selection mode we'll use this layer to query and display the selected permits permits = new esri.layers.FeatureLayer("http://map.miamiconservancy.org:6080/arcgis/rest/services/MCDPropertiesJOINToSQL/MapServer/2", { outFields: ["*"], infoTemplate: popupTemplate, mode: esri.layers.FeatureLayer.MODE_SELECTION }); //add the Properties layer to the map as a feature layer in selection mode properties = new esri.layers.FeatureLayer("http://map.miamiconservancy.org:6080/arcgis/rest/services/MCDPropertiesJOINToSQL/MapServer/0", { outFields: ["*"], infoTemplate: popupTemplateParcels, mode: esri.layers.FeatureLayer.MODE_SELECTION }); permits.setSelectionSymbol(sfs); properties.setSelectionSymbol(sfs); // map.infoWindow.setFeatures(permits); //*****when users click on the map select the permit using the map point and update the url parameter dojo.connect(map, 'onClick', function (e) { var query = new esri.tasks.Query(); query.geometry = e.mapPoint; permits.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (selection) { //update the url param if a permit was located if (selection.length > 0) { var mcdnum = selection[0].attributes["Permits.MASTERUSER.%PERMIT.MCDNUM"]; //Refresh the URL with the currently selected permit if (typeof history.pushState !== 'undefined') { window.history.pushState(null, null, "?mcdnum=" + selection[0].attributes["Permits.MASTERUSER.%PERMIT.MCDNUM"]); } } }); // map.infoWindow.setFeatures(selection); map.infoWindow.setFeatures(permits); map.infoWindow.show(e.mapPoint); }); // Now for the Properties layer dojo.connect(properties, 'onClick', function (e) { var query = new esri.tasks.Query(); query.geometry = e.mapPoint; map.infoWindow.setFeatures(selection); map.infoWindow.show(e.mapPoint); }); dojo.connect(map, 'onLayersAddResult', function (result) { // Add a link into the InfoWindow Actions panel var emailLink = dojo.create("a", { "class": "action", "innerHTML": "Email Map", "href": "javascript:void(0);" }, dojo.query(".actionList", map.infoWindow.domNode)[0]); // Register a function to be called when the user clicks on // the above link dojo.connect(emailLink, "onclick", function (evt) { var feature = map.infoWindow.getSelectedFeature(); var url = window.location; var emailLink = "mailto:?subject=Permit Map of :" + feature.attributes["Permits.MASTERUSER.%PERMIT.MCDNUM"]+ "&body=Check out this permit: %0D%0A " + window.location; window.location.href = emailLink; }); //When users navigate through the history using the browser back/forward buttons select appropriate permit //https://developer.mozilla.org/en/DOM/Manipulating_the_browser_history window.onpopstate = function (event) { var mcdnum = getPermitFromUrl(document.location.href); if (mcdnum) { selectPermit(mcdnum); } else { permits.clearSelection(); map.infoWindow.hide(); } }; //if a mcdnum is specified in url param select that feature var mcdnum = getPermitFromUrl(document.location.href); selectPermit(mcdnum); }); map.addLayers([permits]); map.addLayers([properties]); } //extract the permit id from the url function getPermitFromUrl(url) { var urlObject = esri.urlToObject(url); if (urlObject.query && urlObject.query.mcdnum) { return urlObject.query.mcdnum; } else { return null; } } //select permit from the feature layer by creating a query to look for the input mcdnum id function selectPermit(mcdnum) { if (mcdnum) { var query = new esri.tasks.Query(); query.where = "Permits.MASTERUSER.%PERMIT.MCDNUM = " + mcdnum + ""; //query.where = "Permits.MASTERUSER.%PERMIT.MCDNUM = 2963"; var deferred = permits.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (selection) { var center = esri.graphicsExtent(selection).getCenter(); var extHandler = dojo.connect(map, 'onExtentChange', function () { dojo.disconnect(extHandler); //zoom to the center then display the popup map.infoWindow.setFeatures(selection); map.infoWindow.show(center); }); map.centerAt(center); }); } } dojo.ready(init); </script> </head> <body class="claro"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'" style="border:1px solid #000;padding:0;"></div> </div> </body> </html>
//the code below is taken from your dojo.connect(map,...) dojo.connect(map, 'onClick', function (e) { var query = new esri.tasks.Query(); query.geometry = e.mapPoint; //TODO: consider creating a method that expands the point to an extent //call the method that performs a query from an array of feature layers... //note that you may need to alter the query object .. //my example assumes the same query for all layers in the array var editFeatureLayers = [permits, properties]; var deferred = getSelectionLayerDeferred(editFeatureLayers, query); deferred.then(function (results) { var selectionLayers = null; if (results.success) { selectionLayers = results.selectionLayers; } else { var err = results.error; alert("Error when attempting process selectionLayers for the EditLayers"); } if (selectionLayers) { if (selectionLayers.length > 0) { //add your code here to process your selected records.. //below is an example how you can get the info you need from the selectionLayers object var mySelfeatures = []; dojo.forEach(selectionLayers, function (selLayer) { var layerNameString = selLayer.featureLayer.name; var selFeatures = selLayer.features; var selFeatureCount = selLayer.features.length; //NOTE: in here you can process your logic as needed based on your layerNameString for example //added some pseudocode below to show you what I mean: if (layerNamestring === "premits") { } else if (layerNamestring === "properties") { } //note, you may need to create an array object to add all your featuers //so you can use it to setFeatures for your popup //don't know, haven't done this before since I use the attributeInspector //concat the selFeatures to this array... I think this will work confirm syntax in JS mySelfeatures = mySelfeatures.concat(selLayer.features); }); } else { //hideProcessingDialog(); //add your code here to add logic to what happens if no features get selected } } }, function (err) { // Do something on failure. hideProcessingDialog(); drawToolbar.deactivate(); alert("Error while selecting features"); }); map.infoWindow.setFeatures(mySelfeatures); //map.infoWindow.setFeatures(permits); map.infoWindow.show(e.mapPoint); }); //BELOW is the method that performs the selection from an array of FeatureLayer objects and uses one Query object // this is really key to being able to get all the selection results in one place ... it is also pretty fast since it does not chain the //call to the server all calls are done asynch... //TODO: use dojo/promise/all instead of dojo/deferredList function getSelectionLayerDeferred(featureLayerArray, selectQuery) { var returnDeferred = null; var selectionLayers = []; var defferredCallArray = []; require(["dojo/DeferredList", "dojo/Deferred"], function (DeferredList, Deferred) { returnDeferred = new Deferred(); dojo.forEach(featureLayerArray, function (flayer) { var defferredCall = flayer.selectFeatures(selectQuery, esri.layers.FeatureLayer.SELECTION_NEW); //cast the dojo.deferred to a promise so we can use the new //dojo/promise/all in lieu of dojo/DeferredList (deprecated at v 1.8) defferredCallArray.push(defferredCall); }); var dl = new DeferredList(defferredCallArray); dl.then(function (results) { // Executed when all deferred resolved if (results.length > 0) { dojo.forEach(results, function (result) { if (result[0] === true && result[1].length > 0) { selectionLayers.push({ 'featureLayer': result[1][0].getLayer(), 'features': result[1] }); } }); } returnDeferred.resolve({ 'success': true, 'selectionLayers': selectionLayers }); }, function (err) { returnDeferred.resolve({ 'success': false, 'selectionLayers': null, 'error': err }); }); }); return returnDeferred; }
