Can't view layers on samsung s10
982
06-12-2020 04:37 AM
מנהל_תקשובמנהל_מערכת
hi all ,
I've created jsAPI 4.15 map which can be  viewed and operate in many devices apple and android except the samsung galaxy s10 series, including note.
It seems to effect only vector layers not tile layers, , when you loads the map you can view only tile layers.
It also effects maps which loads  webmap item , it just does not display the map.
I not sure what is the problem , maybe last update of ONE UI 2.1 ,
you can check it with ESRI samples:
Intro to FeatureLayer - 4.15
Load a basic WebMap - 4.15
does any one know how to workaround?
I'm enclosing my phone settings.
