Can't load map for the sample code
1388
05-17-2014 09:59 AM
JisikiYeah
HI,
I am a starter,
When I download the samplecode from http://developers.arcgis.com/javascript/sandbox/sandbox.html?sample=map_webmap
Which is a simple code for loading the arcgis map with     <div id="mapDiv"></div>
    <div id="legendDiv"></div>
But , when I download the code and run it on my browser,  the map can't be loaded, there is blank in my chrome and IE,
BenFousek
Welcome to the forum.
Just a guess, but are you loading the the file from a file or via a web server? It won't work if you are loading it from a file, i.e. file:///C:/sample/index.html. If so, you need to use a local web server, use an IDE with one built in, use a real web server, etc. Then load the file via http://localhost/sample/index.html for example.
JisikiYeah
Thanks,  after loading to the tomcat,   it works. .
BenFousek
Glad to help. Please mark this post as answered so others know your issue is resolved. Thanks.
