can't interact with feature table widget, api version 3.20
2416
6
05-02-2017 02:50 PM
KirstenLawrence
I developed a widget that loads the esri feature table widget in an app using api version 3.17. When I change my api reference in the app to 3.20, I can no longer interact with the feature table - rows are not selectable, nothing is clickable, though the feature table does load as it should. Any ideas out there?
RobertScheitlin__GISP
Kirsten,
   Have you checked the browsers web console?
KirstenLawrence
Yes it doesn't give an errors
Kirsten,
  Can you share your code for debugging?
KirstenLawrence
Here is a link to the code for the widget with a highlight on where the feature table is created. Thanks for looking
LayerFilter.js · GitHub
Hmm.. I'm not seeing the issue.
deleted-user-iPdcWUgWcsoy
I've got the same problem. I've tried to add the FeatureTable to different dom nodes or layout widgets and I still get this problem. Now my workaround is to delete the "_trailingPaneNode" of this widget.
var myFeatureTable = new FeatureTable({
    featureLayer : featureLayer,
    map : this.map,
    syncSelection : true,
    outFields: ["*"]
}).placeAt(this.domNode);
myFeatureTable._trailingPaneNode.destroy();
Somehow there is a problem with some style or something in this node. After I delete this node I can interact with the widget.
