Can't get the value for my field in my PopupTemplate
4295
12-03-2015 02:40 PM
TracySchloss
Honored Contributor
Maybe someone can spot what I'm missing.  I have a popupTemplate based on data that is from a linked table.  I am creating a pie chart.  All the values for the chart are in the join table, and from the layer, I just need county name.  Both the layer and the table are in a file geodatabase.
If I create a plain infoTemplate, defined as
var genericInfoTemplate = new InfoTemplate("generic", "${*}");
I can see all the values I want, both from the layer and the joined table.  The county name is available as county.COUNTYNAME
Here is my rest endpoint:
Layer: Veteran Population by Race - current (ID: 2)
Here is how I'm trying to defined my popupTemplate:
  var raceTemplate = new PopupTemplate({
    title: "{county.COUNTYNAME}: Current Veteran Population by Race",
    fieldInfos: [{
        fieldName: "VetPop_current_Race.EstAsianVetPop",
        visible: true,
        format: { places: 0 },
        label:"Asian"
        fieldName: "VetPop_current_Race.EstBlackVetPop",
        visible: true,
        label:"Black"
        fieldName: "VetPop_current_Race.EstHispanicVetPop",
        visible: true,
        label:"Hispanic"
        fieldName: "VetPop_current_Race.EstWhiteVetPop",
        visible: true,
        label:"White"
        fieldName: "VetPop_current_Race.EstMultiRaceVetPop",
        visible: true,
        label:"Multi-Race"
        fieldName: "VetPop_current_Race.EstOtherVetPop",
        visible: true,
        label:"Other"
    mediaInfos: [{
      type: "piechart",
      caption: "Hover to see value for each race",
        value: {
          fields: [
            "VetPop_current_Race.EstWhiteVetPop" ,
          theme: "PrimaryColors"
Besides not using PopupTemplates very often, this is also the first time I've defined infoTemplates in an ArcGISDynamicMapServiceLayer using myLayername.setInfoTemplates.  I don't know if that makes any difference or not.
RobertScheitlin__GISP
Tracy,
  You just needed to include the county.COUNTYNAME field in your fieldInfos array
        fieldInfos: [{
          visible: true,
          format: {
            places: 0
          label: "Asian"
          visible: true,
          format: {
            places: 0
          label: "Black"
          visible: true,
          format: {
            places: 0
          label: "Hispanic"
          visible: true,
          format: {
            places: 0
          label: "White"
          visible: true,
          format: {
            places: 0
          label: "Multi-Race"
          visible: true,
          format: {
            places: 0
          label: "Other"
          fieldName: "county.COUNTYNAME",
          visible: false
        mediaInfos: [{
          type: "piechart",
          value: {
            fields: [
Tracy,
        fieldInfos: [{
          visible: true,
          format: {
            places: 0
          label: "Asian"
          visible: true,
          format: {
            places: 0
          label: "Black"
          visible: true,
          format: {
            places: 0
          label: "Hispanic"
          visible: true,
          format: {
            places: 0
          label: "White"
          visible: true,
          format: {
            places: 0
          label: "Multi-Race"
          visible: true,
          format: {
            places: 0
          label: "Other"
          visible: false
        mediaInfos: [{
          type: "piechart",
          value: {
            fields: [
TracySchloss
Honored Contributor
Thanks - now I'm trying to include a description under the title.  This is just a string, not pulling from a value.  When I add this, it only loads my title and my chart, but none of the values.
This seems to match the examples.  I'm adding it right below the title:
description: "Population values for 2015",
     fieldInfos: [{
Tracy,
  It is either or. You can use description or if you do not use description then the popup will use the fieldinfos that are set to visible and display those in a table layout format. If you want to add some static text as a description then you have to add all your field values text to the description as well.
Here is a example (just using Asian):
var popupDescTemplate = 'Population values for 2015<br><table class="attrTable" cellpadding=0px" cellspacing="0px"><tbody>' +
          '<tr valign="top"><td class="attrName">Asian</td><td class="attrValue">{VetPop_current_Race.EstAsianVetPop}</td></tr>' +
          '</tbody></table>';
        description: popupDescTemplate,
        fieldInfos: [{
          visible: true,
          format: {
            places: 0
          label: "Asian"
          visible: true,
          format: {
            places: 0
          label: "Black"
          visible: true,
          format: {
            places: 0
          label: "Hispanic"
          visible: true,
          format: {
            places: 0
          label: "White"
          visible: true,
          format: {
            places: 0
          label: "Multi-Race"
          visible: true,
          format: {
            places: 0
          label: "Other"
          visible: false
        mediaInfos: [{
          type: "piechart",
          value: {
            fields: [
TracySchloss
Honored Contributor
I was hoping for something obvious I wasn't seeing, but at least there's a way to have both.
