Can I zoom into a polygon with buffer?
1200
02-21-2017 08:41 AM
LindaM
I need to let the map zoom into a free-draw polygon’s buffer; the buffer can be 10 – 100 miles defined by the users, the buffer value is defined as BufferDistance.
I know for a circle with buffer, it can be defined such as
var circleBuffer = new Circle(centerPoint, {
                "radius": this.circle.radiusValue
And then the map extent is set as:
this.map.setExtent(circleBuffer.getExtent());
I test this circle statement, it can zoom into the circle buffer very well.
My question is: what if I want to zoom into a free-draw polygon with buffer? How do I get the extent of this polygon with buffer (not just polygon itself)?  In esri/geometry domain, a polygon constructor does not include any optional parameter like radius/buffer. I tried the following:
this.map.setExtent(polygon.geometry.getExtent());
It can only zoom into the polygon itself, not the polygon buffer. Thanks!
RobertScheitlin__GISP
Linda,
   You have to use the GeometryService buffer method first and use the returned promise to set the maps extent.
GeometryService | API Reference | ArcGIS API for JavaScript 3.19 | buffer
Linda,
