Can I use cursors in a geoprocessing service?
3374
6
08-30-2013 10:53 AM
ionarawilson1
Can I use cursors (search, insert and update cursors) in a geoprocessing service that is going to be used in a web app? Thanks
ionarawilson1
A note on the last note: If use arcpy.GeParameterAsText() it works in arcmap but not when running the gp, because apparently a parameter cannot have a feature class as an input (go figure!), so if you use arcpy.GetParameterAsText() and then have that parameter as a featureset (which I needed for my gp) it won't work in the gp. What I did was to create a variable for that parameter and when I run it inside ArcMap I grab the layer for that feature class (in my case the layer is referencing a feature class in a sde geodatabase). Then I publish the gp, then when I run the geoprocessing service I can grab the file directly from the connection instead of the layer. I hope it will help somebody because it took me a while to figure this out.
 Input_Polygons = "Stewardship"    with arcpy.da.UpdateCursor(Input_Polygons, ("DateStart", "PlanID", "FFY")) as rows:      for row in rows:          if not (row[1] or "").strip(): #covers blank, one blank space, or Null             Datestarstr1 = row[0]             Datestarstr2 = str(Datestarstr1)                      yearonly = Datestarstr2[0:4]                               row[2] = yearonly              rows.updateRow(row)
DanielSmith
Any answer to this? Currently working with an update cursor in a python script. Script runs fine stand alone and as a geoprocessing tool. Service says it finishes w/o errors but the table is not updated.
many thanks
ionarawilson1
Yes, we can use all the cursors, the problem is usually with the data input. Here is something that works for me. For the inputs (the inputpolygons) make sure you create a python toolbox parameter as a feature set. To make the update occur in the geoprocessing service, make sure when you run the tool in ArcMap that you select the inputs from their actual files (their databases), not the layers in your map. It took a while for me to figure out this. Of course, make sure the arcgisserver can access the data before through the data store. Good luck!
# Import arcpy module
import os, sys, arcpy, traceback, arcgisscripting
    for row in rows:
           row[2] = yearonly
           rows.updateRow(row)
DanielSmith
thank you very much. i will test this now. The data will be local to the user so we'll see how this shakes out soon.
ionarawilson1
No problem. Make sure you check the logs in the manager also. It can give you a clue about the problem.
ionarawilson1
Just a note:
When I started adding more feature class, things stopped working, so I changed this
Counties = "Counties"
to
Input_Polygons = arcpy.GetParameterAsText(0)
Counties = arcpy.GetParameterAsText(1)
And Everything is working again!
ionarawilson1
