Can I eliminate the redundant points after running GeometryService.simplify?
1280
08-04-2014 03:26 AM
StephenLam
I am trying to implement a buffer zone search, after I read this, using GeometryService.simplify
gsvc.simplify([evt.geometry], function (geometries) {
      params.geometries = geometries;
      gsvc.buffer(params, showBuffer);
I successfully get a buffered geometry, say rectangle, however the returned geometry has a lot of vertex at the corners, so it is inconvenient to modify the shape...Is it possible to just get a "4 points rectangle" with buffered size? Thanks.
RobertScheitlin__GISP
Stephen,
  Simplify takes care of counter clockwise polygon orientation and polygon self-intersecting, etc. I think what you want is the GeometryService.Generalize
Stephen,
RiyasDeen
Hi Stephen,
1. One option is to get envelope of the buffer geometry, this will always be a 4 point rectangle.
2. If you are looking for a minimum bounding rectangle then you may want to create a geoprocessing service using minimum bounding geometry tool. Refer below links on how to go about it.
Minimum bounding geometry task - ArcGIS Desktop
Publishing geoprocessing service - ArcGIS Help 10.1
